I am currently trying to make the switch from Inviwo to Paraview but the Plugin/module structure seems to elude me.
The project structure I have so far looks like as shown below. I have more filters but for the sake of simplicity I’ll only go through one here. The code is available at OpenTensorVis.
├── CMakeLists.txt
├── OpenTensorVis
│ ├── CMakeLists.txt
| |── opentensorvis.plugin
│ ├── TensorFieldCriticalCellsFilter
│ │ ├── CMakeLists.txt
│ │ ├── tensorfieldcriticalcells.module
│ │ ├── TensirFieldCriticalCellsFilter.xml
│ │ ├── vtkTensorFieldCriticalCells.cxx
│ │ └── vtkTensorFieldCriticalCells.h
The top level CMakeLists.txt contains
cmake_minimum_required(VERSION 3.8)
project(OpenTensorVis-ParaView-Plugins)
find_package(ParaView REQUIRED)
set(CMAKE_CXX_STANDARD 20)
option(BUILD_SHARED_LIBS "Build shared libraries" ON)
include(GNUInstallDirs)
set(CMAKE_RUNTIME_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${CMAKE_INSTALL_BINDIR}")
set(CMAKE_LIBRARY_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${CMAKE_INSTALL_LIBDIR}")
set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${CMAKE_INSTALL_LIBDIR}")
set("_paraview_plugin_default_${CMAKE_PROJECT_NAME}" ON)
paraview_plugin_scan(
PLUGIN_FILES "${CMAKE_CURRENT_SOURCE_DIR}/OpenTensorVis/opentensorvis.plugin"
PROVIDES_PLUGINS opentensorvis
REQUIRES_MODULES required_modules)
foreach (module IN LISTS required_modules)
if (NOT TARGET "${module}")
message(#FATAL_ERROR
"Skipping example ${CMAKE_PROJECT_NAME}: Missing required module: "
"${module}")
return ()
endif ()
endforeach ()
paraview_plugin_build(
RUNTIME_DESTINATION "${CMAKE_INSTALL_BINDIR}"
LIBRARY_DESTINATION "${CMAKE_INSTALL_LIBDIR}"
LIBRARY_SUBDIRECTORY "${PARAVIEW_PLUGIN_SUBDIR}"
PLUGINS ${opentensorvis})
The opentensorvis.plugin file:
NAME
OpenTensorVis
DESCRIPTION
Implementations of the algorithms and methods developed in the OpenTensorVis project.
REQUIRES_MODULES
VTK::CommonCore
VTK::FiltersCore
The CMakeLists.txt for the plugin simply contains
paraview_add_plugin(OpenTensorVis
VERSION "1.0"
MODULES
OpenTensorVis::TensorFieldCriticalCellsFilter
MODULE_FILES
"${CMAKE_CURRENT_SOURCE_DIR}/TensorFieldCriticalCellsFilter/tensorfieldcriticalcells.module"
Last but not least, the tensorfieldcriticalcells.module file defines a simple module:
NAME
LIBRARY_NAME
vtkTensorFieldCriticalCellsFilter
DEPENDS
VTK::FiltersCore
PRIVATE_DEPENDS
VTK::CommonCore
with a corresponding CMakeLists.txt:
set(vtkTensorFieldCriticalCellsClasses
vtkTensorFieldCriticalCells)
vtk_module_add_module(OpenTensorVis::TensorFieldCriticalCellsFilter
CLASSES ${vtkTensorFieldCriticalCellsClasses})
paraview_add_server_manager_xmls(
XMLS TensorFieldCriticalCellsFilter.xml
CMake runs fine and everything compiles but when trying to load the plugin, ParaView throws the error
ERROR: In C:\bbd\6c27b535\build\superbuild\paraview\src\Remoting\Core\vtkPVPluginLoader.cxx, line 519
vtkPVPluginLoader (000001D855F1F2F0): The specified module could not be found.
I suppose I am mixing things up somewhere and I’d be happy about pointers as to where to look. Thanks!
