Paraview - Poor performance -Ubuntu
Hi every one,
I have a problem with Paraview 5.6.0 - 64 Bit on Ubuntu 18.04. Although I have a strong configuration with two Epyc 7402 24-core, 128 Go Ram and a RTX 2070 super, the software is very slow (low frame-rate) on Ubuntu 18.04. I already try with the new version on Ubuntu 20 and with NVidia driver and XX.org driver… I don’t have this problem on windows (I have a dualboot).
Has anyone an idea of what could be the problem?
Thanks a lot in advance for your help!
Best,
Guilhem
  1. Update to ParaView 5.9.0
  2. Check the your dirvers on in use by sharing the content on the Help -> About dialog
Thanks for your answer! I don’t know how to update paraview as I use paraview with openFoam, i.e. I use paraFoam.
When I go in Help -> About, i have :
Once again, thx for your help.
Best,
Guilhem
You are using mesa,you are not using your GPU, what is the output of ?
glxinfo | grep Vendor
In any case, download the last version of ParaView for your system here:
The output of glxinfo | grep vendor is :
server glx vendor string: NVIDIA Corporation
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
Is it possible to choose between Mesa and the GPU directly in paraview?
yes, I will install the latest version of paraview.
Thx
ParaView should detect your GPU automatically unless you are using options or configurations.
Let me kow how it goes with a newer ParaView
It works fine with the new version of paraview (5.9)! There is OpenGL NVidia. Thx a lot!
Don’t know why “paraFoam” use OpenGL with MESA… Is there an option to modify?
You will have to ask paraFOAM developpers.
@olesenm
@Dellinger Probably too vague to write about “paraFoam”. The OpenFOAM reader module is just a module, it has no impact on OpenGL/MESA etc, those are all defined by ParaView itself.
As @mwestphal noted, it is best to try with a fresh binary of 5.9.0, so that we know that we are all speaking of the same thing. Use the regular native ParaView/VTK reader for the OpenFOAM files. It works for the vast majority of cases.
See the entry “Do I really need the ParaView plugins?” for a quick overview.
Yes I will stay on the 5.9 version of paraview instead using paraFoam which launch paraview 5.6.
Thx a lot for your help!
You may also wish to use one of the OpenFOAM Ubuntu packages that we maintain:
Here are the installation instructions.
Note that this one has a finely granulated set of sub-packages, so you install as much as you need.
The openfoam shell session makes it easy to quickly run a different version.
The openfoam-selector provides a mechanism for more permanent switching of versions.
Thx Mark, I will try!
