paraview pvpython error while saving csv data
I am trying to automate my postprocessing and I wrote a script that loads the data, does some clipping and then applies the streamtracer filter. Then I save the result of the streamtracer as a .csv file. When I run the script from the terminal using pvpython, I get this error:
  File "/data/sponges/Type_C/Lambda1/Re_00500/paraview_streamlines_macro.py", line 198, in <module>
    saveStreamlineCSV(file)
  File "/data/sponges/Type_C/Lambda1/Re_00500/paraview_streamlines_macro.py", line 165, in saveStreamlineCSV
    SaveData('cdv/filename[:4]}.csv', proxy=streamTracer1, ChooseArraysToWrite=1,
  File "/opt/ParaView-5.13.2-MPI-Linux-Python3.10-x86_64/lib/python3.10/site-packages/paraview/simple.py", line 1799, in SaveData
    writer = CreateWriter(filename, proxy, **extraArgs)
  File "/opt/ParaView-5.13.2-MPI-Linux-Python3.10-x86_64/lib/python3.10/site-packages/paraview/simple.py", line 1777, in CreateWriter
    writer_proxy.UnRegister(None)
AttributeError: 'NoneType' object has no attribute 'UnRegister'
error: exception occurred: Segmentation fault
I don’t understand if the syntax is wrong or I have to use a entirely different procedure to write the data as a csv.
Trying a few things with ParaView 5.13.2 locally on my Mac with SaveData, I’m not reproducing your error. Could you share the script, at least the full call to SaveData? Thanks.
import os
import re
from paraview.simple import *
work_dir = os.getcwd()
def saveStreamlineCSV(filename):
   ResetSession()
   #### disable automatic camera reset on 'Show'
   # create a new 'Legacy VTK Reader'
   #tec_3d011404000000vtk = LegacyVTKReader(FileNames=[f"work_dir/{filename}"])
   #paraview.simple._DisableFirstRenderCameraReset()
   tec_3d014402000000vtk = LegacyVTKReader(registrationName='tec_3d.0144.02000000.vtk', FileNames=['work_dir/{filename}'])
   # get active view
   # show data in view
   tec_3d014402000000vtkDisplay = Show(tec_3d014402000000vtk, renderView1, 'UniformGridRepresentation')
   # trace defaults for the display properties.
   tec_3d014402000000vtkDisplay.Representation = 'Outline'
   # reset view to fit data
   renderView1.ResetCamera(False, 0.9)
   # get the material library
   materialLibrary1 = GetMaterialLibrary()
   # update the view to ensure updated data information
   renderView1.Update()
   # set scalar coloring
   ColorBy(tec_3d014402000000vtkDisplay, ('POINTS', 'velocity', 'Magnitude'))
   # rescale color and/or opacity maps used to include current data range
   tec_3d014402000000vtkDisplay.RescaleTransferFunctionToDataRange(True, False)
   # show color bar/color legend
   tec_3d014402000000vtkDisplay.SetScalarBarVisibility(renderView1, True)
   # get color transfer function/color map for 'velocity'
   velocityLUT = GetColorTransferFunction('velocity')
   # get opacity transfer function/opacity map for 'velocity'
   velocityPWF = GetOpacityTransferFunction('velocity')
   # get 2D transfer function for 'velocity'
   velocityTF2D = GetTransferFunction2D('velocity')
   # change representation type
   tec_3d014402000000vtkDisplay.SetRepresentationType('Surface')
   # create a new 'Clip'
   clip1 = Clip(registrationName='Clip1', Input=tec_3d014402000000vtk)
   # toggle interactive widget visibility (only when running from the GUI)
   ShowInteractiveWidgets(proxy=clip1.ClipType)
   # Properties modified on clip1
   clip1.ClipType = 'Cylinder'
   clip1.Scalars = ['POINTS', '']
   # Properties modified on clip1.ClipType
   clip1.ClipType.Center = [165.0, 200.5, 400.5]
   clip1.ClipType.Axis = [0.0, 0.0, 1.0]
   clip1.ClipType.Radius = 99.0
   # show data in view
   clip1Display = Show(clip1, renderView1, 'UnstructuredGridRepresentation')
   clip1Display.Representation = 'Surface'
   # hide data in view
   Hide(tec_3d014402000000vtk, renderView1)
   clip1Display.SetScalarBarVisibility(renderView1, True)
   clip2 = Clip(registrationName='Clip2', Input=clip1)
   # Properties modified on clip2
   clip2.Scalars = ['POINTS', '']
   # Properties modified on clip2.ClipType
   clip2.ClipType.Origin = [165.0, 200.50000000000006, 720.0]
   clip2.ClipType.Normal = [0.0, 0.0, 1.0]
   # show data in view
   clip2Display = Show(clip2, renderView1, 'UnstructuredGridRepresentation')
   clip2Display.Representation = 'Surface'
   # hide data in view
   Hide(clip1, renderView1)
   clip2Display.SetScalarBarVisibility(renderView1, True)
   clip3 = Clip(registrationName='Clip3', Input=clip2)
   # Properties modified on clip3
   clip3.Scalars = ['POINTS', '']
   # Properties modified on clip3.ClipType
   clip3.ClipType.Origin = [165.0, 200.50000000000006, 230.0]
   clip3.ClipType.Normal = [0.0, 0.0, -1.0]
   # show data in view
   clip3Display = Show(clip3, renderView1, 'UnstructuredGridRepresentation')
   clip3Display.Representation = 'Surface'
   # hide data in view
   Hide(clip2, renderView1)
   clip3Display.SetScalarBarVisibility(renderView1, True)
   # create a new 'Stream Tracer'
   streamTracer1 = StreamTracer(registrationName='StreamTracer1', Input=clip3,
       SeedType='Line')
   ShowInteractiveWidgets(proxy=streamTracer1.SeedType)
   # Properties modified on streamTracer1
   streamTracer1.MaximumStreamlineLength = 10000.0
   streamTracer1.SeedType = 'Point Cloud'
   # show data in view
   streamTracer1Display = Show(streamTracer1, renderView1, 'GeometryRepresentation')
   streamTracer1Display.Representation = 'Surface'
   # hide data in view
   Hide(clip3, renderView1)
   streamTracer1Display.SetScalarBarVisibility(renderView1, True)
   # save data
       PointDataArrays=['IntegrationTime', 'velocity'],
       CellDataArrays=['ReasonForTermination', 'SeedIds'])
   # set active source
   SetActiveSource(tec_3d014402000000vtk)
   ShowInteractiveWidgets(proxy=tec_3d014402000000vtkDisplay.SliceFunction)
   ShowInteractiveWidgets(proxy=tec_3d014402000000vtkDisplay)
   HideInteractiveWidgets(proxy=tec_3d014402000000vtkDisplay.SliceFunction)
   HideInteractiveWidgets(proxy=tec_3d014402000000vtkDisplay)
   HideInteractiveWidgets(proxy=streamTracer1.SeedType)
   # save data
   SaveData('{filename[:-4]}.csv', proxy=streamTracer1, PointDataArrays=['AngularVelocity', 'IntegrationTime', 'Normals', 'Rotation', 'Vorticity', 'velocity'],
saveEach = 4
data = {}
#os.walk
for file in os.listdir(work_dir):
    if file.startswith('tec_3d'):
        print(file)
The problem starts at this line. I think the file name is missing a {, which may be causing a problem with determining which writer to use. That call to SaveData seems to work fine on my Mac, however - the file name is just funky.
