paraview-python: Could not import vtkCommonComputationalGeometry
I try to run a python script (test.py) containing this line only:
`from paraview.simple import *`
I want to use the last version of paraview. So, I downloaded it from the official webpage and I uncompressed the corresponding archive into a folder, say /home/paraview.
If I do not anything more than running the script with
`python test.py`
I get the following error message:
    > Traceback (most recent call last):
    > File "test.py", line 2, in <module>
    > ModuleNotFoundError: No module named 'paraview
So, I set my PYTHONPATH like this:
`export PYTHONPATH=/home/paraview/lib/python2.7/site-packages:$PYTHONPATH`
Then, I rerun my script and I get a different error message:
> Error: Could not import vtkCommonComputationalGeometry
> Segmentation fault
I tried to set LD_LIBRARY_PATH:
`export LD_LIBRARY_PATH=/home/paraview/lib`
where vtkCommonComputationalGeometry.so is but it does not work.
Furthermore, if I try to locate vtkCommonComputationalGeometry, I find it in another location:
`/usr/lib/x86_64-linux-gnu/libvtkCommonComputationalGeometry-6.2.so`
I removed vtk with apt but it is still here.
Do you know how I could run my script?
There are a number of libraries you will need to add to your path in order to use paraview in your standard Python environment. I haven’t had much luck doing that in that past…
If you downloaded the prebuilt ParaView, then there should be a pvpython executable that you should use as your Python interpreter. This is usually under the bin/ directory.
It works fine! Thank you very much!
