Hello, I have the following python script that runs without problem on my local machine.
from paraview.simple import GetSources
all_sources = GetSources()
for s_string,s_id in all_sources:
source = all_sources[s_string, s_id]
print(s_string)
print(source)
print(source.SMProxy.GetClientSideObject().GetClassName())
which gives, having an OF reader in the pipeline:
simulation.foam
<paraview.servermanager.OpenFOAMReader object at 0x7ff4f78d4510>
vtkPOpenFOAMReader
Now, when I run the same script on the remote server I get
simulation.foam
<paraview.servermanager.OpenFOAMReader object at 0x7fc088033a10>
File "<string>", line 24, in <module>
AttributeError: 'NoneType' object has no attribute 'GetClassName'
which means that source.SMProxy.GetClientSideObject() is None.
The question, do I have to modify something in particular to make it work on a remote server ?
Thank you for any help.
Edit: Paraview version is
ParaView-5.8.1-MPI-Linux-Python3.7-64bit
