Hello All,
I have less knowledge and experience about paraview python scripting.
I have paraview python script, partly generated by paraview and partly created by me (thanks to the ‘macro record’ option creator, I hope the person live long enough).
Script functionality:
1.The script essentially takes the file readable by paraview from openfoam avilable in that directory
2.processes some graphical option changes and adjustments
3.then moves towards calculation of ‘isovolumedisplay’ and from that calculates ‘alpha.water’ using ‘integrateVariable’
4.Shows calculated value in shreadsheet format.
From that I copy the value manually and paste it in Excel cell.
Program:
#!usr/bin/python
#script to automate the process of calculating volume fraction (also called as void fraction) alpha
#and show graphically
#### import the simple module from the paraview
from paraview.simple import *
#### disable automatic camera reset on 'Show'
# create a new 'OpenFOAMReader'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAM = OpenFOAMReader(registrationName='3D_Case20_halfGeom_(70)_FlR_0_0009631_Water.OpenFOAM', FileName='E:\\CCS\\3D_cases\\H2O_Cases\\halfGeom\\3D_Case20_halfGeom_(70)_FlR_0_0009631_Water\\3D_Case20_halfGeom_(70)_FlR_0_0009631_Water.OpenFOAM')
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAM.MeshRegions = ['internalMesh']
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAM.CellArrays = ['U', 'UMean', 'UPrime2Mean', 'alpha.water', 'alpha.waterMean', 'alpha.waterPrime2Mean', 'p', 'pMean', 'pPrime2Mean', 'p_rgh']
# get animation scene
animationScene1 = GetAnimationScene()
# update animation scene based on data timesteps
animationScene1.UpdateAnimationUsingDataTimeSteps()
# Properties modified on a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAM
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAM.LabelSize = '64-bit'
# get active view
# show data in view
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay = Show(a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAM, renderView1, 'UnstructuredGridRepresentation')
# get color transfer function/color map for 'p'
pLUT = GetColorTransferFunction('p')
# get opacity transfer function/opacity map for 'p'
pPWF = GetOpacityTransferFunction('p')
# trace defaults for the display properties.
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.Representation = 'Surface'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.ColorArrayName = ['POINTS', 'p']
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.LookupTable = pLUT
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.SelectTCoordArray = 'None'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.SelectNormalArray = 'None'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.SelectTangentArray = 'None'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.OSPRayScaleArray = 'p'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.OSPRayScaleFunction = 'PiecewiseFunction'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.SelectOrientationVectors = 'U'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.ScaleFactor = 0.01
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.SelectScaleArray = 'p'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.GlyphType = 'Arrow'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.GlyphTableIndexArray = 'p'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.GaussianRadius = 0.0005
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.SetScaleArray = ['POINTS', 'p']
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.ScaleTransferFunction = 'PiecewiseFunction'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.OpacityArray = ['POINTS', 'p']
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.OpacityTransferFunction = 'PiecewiseFunction'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.DataAxesGrid = 'GridAxesRepresentation'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.PolarAxes = 'PolarAxesRepresentation'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.ScalarOpacityFunction = pPWF
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.ScalarOpacityUnitDistance = 0.0018
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.OpacityArrayName = ['POINTS', 'p']
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.ExtractedBlockIndex = 1
# init the 'PiecewiseFunction' selected for 'ScaleTransferFunction'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.ScaleTransferFunction.Points = [375.79, 0.0, 0.5, 0.0, 606.7, 1.0, 0.5, 0.0]
# init the 'PiecewiseFunction' selected for 'OpacityTransferFunction'
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.OpacityTransferFunction.Points = [375.79, 0.0, 0.5, 0.0, 606.7, 1.0, 0.5, 0.0]
# reset view to fit data
renderView1.ResetCamera()
# get the material library
materialLibrary1 = GetMaterialLibrary()
# show color bar/color legend
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAMDisplay.SetScalarBarVisibility(renderView1, True)
# update the view to ensure updated data information
renderView1.Update()
# create a new 'Clip'
clip1 = Clip(registrationName='Clip1', Input=a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAM)
clip1.ClipType = 'Plane'
clip1.HyperTreeGridClipper = 'Plane'
clip1.Scalars = ['POINTS', 'p']
clip1.Value = 491.24
# init the 'Plane' selected for 'ClipType'
clip1.ClipType.Origin = [0, 0, 0.0065]
# init the 'Plane' selected for 'HyperTreeGridClipper'
clip1.HyperTreeGridClipper.Origin = [0, 0, 0.0065]
# Properties modified on clip1.ClipType
clip1.ClipType.Origin = [0.0, -0.045, 0.0]
clip1.ClipType.Normal = [0.0, 1.0, 0.0]
# show data in view
clip1Display = Show(clip1, renderView1, 'UnstructuredGridRepresentation')
clip1Display.Representation = 'Surface'
clip1Display.ColorArrayName = ['POINTS', 'p']
clip1Display.LookupTable = pLUT
clip1Display.SelectTCoordArray = 'None'
clip1Display.SelectNormalArray = 'None'
clip1Display.SelectTangentArray = 'None'
clip1Display.OSPRayScaleArray = 'p'
clip1Display.OSPRayScaleFunction = 'PiecewiseFunction'
clip1Display.SelectOrientationVectors = 'U'
clip1Display.ScaleFactor = 0.0024
clip1Display.SelectScaleArray = 'p'
clip1Display.GlyphType = 'Arrow'
clip1Display.GlyphTableIndexArray = 'p'
clip1Display.GaussianRadius = 0.00012
clip1Display.SetScaleArray = ['POINTS', 'p']
clip1Display.ScaleTransferFunction = 'PiecewiseFunction'
clip1Display.OpacityArray = ['POINTS', 'p']
clip1Display.OpacityTransferFunction = 'PiecewiseFunction'
clip1Display.DataAxesGrid = 'GridAxesRepresentation'
clip1Display.PolarAxes = 'PolarAxesRepresentation'
clip1Display.ScalarOpacityFunction = pPWF
clip1Display.ScalarOpacityUnitDistance = 0.00113
clip1Display.OpacityArrayName = ['POINTS', 'p']
clip1Display.ExtractedBlockIndex = 1
clip1Display.ScaleTransferFunction.Points = [418.45, 0.0, 0.5, 0.0, 592.33, 1.0, 0.5, 0.0]
clip1Display.OpacityTransferFunction.Points = [418.45, 0.0, 0.5, 0.0, 592.33, 1.0, 0.5, 0.0]
# hide data in view
Hide(a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAM, renderView1)
clip1Display.SetScalarBarVisibility(renderView1, True)
clip1.Invert = 0
clip2 = Clip(registrationName='Clip2', Input=clip1)
clip2.ClipType = 'Plane'
clip2.HyperTreeGridClipper = 'Plane'
clip2.Scalars = ['POINTS', 'p']
clip2.Value = 491.24
clip2.ClipType.Origin = [0, 0.0038, 0.0065]
clip2.HyperTreeGridClipper.Origin = [0, 0.0038, 0.0065]
# Properties modified on clip2.ClipType
clip2.ClipType.Origin = [0.0, 0.045, 0.0]
clip2.ClipType.Normal = [0.0, 1.0, 0.0]
# show data in view
clip2Display = Show(clip2, renderView1, 'UnstructuredGridRepresentation')
clip2Display.Representation = 'Surface'
clip2Display.ColorArrayName = ['POINTS', 'p']
clip2Display.LookupTable = pLUT
clip2Display.SelectTCoordArray = 'None'
clip2Display.SelectNormalArray = 'None'
clip2Display.SelectTangentArray = 'None'
clip2Display.OSPRayScaleArray = 'p'
clip2Display.OSPRayScaleFunction = 'PiecewiseFunction'
clip2Display.SelectOrientationVectors = 'U'
clip2Display.ScaleFactor = 0.009
clip2Display.SelectScaleArray = 'p'
clip2Display.GlyphType = 'Arrow'
clip2Display.GlyphTableIndexArray = 'p'
clip2Display.GaussianRadius = 0.00045
clip2Display.SetScaleArray = ['POINTS', 'p']
clip2Display.ScaleTransferFunction = 'PiecewiseFunction'
clip2Display.OpacityArray = ['POINTS', 'p']
clip2Display.OpacityTransferFunction = 'PiecewiseFunction'
clip2Display.DataAxesGrid = 'GridAxesRepresentation'
clip2Display.PolarAxes = 'PolarAxesRepresentation'
clip2Display.ScalarOpacityFunction = pPWF
clip2Display.ScalarOpacityUnitDistance = 0.0016
clip2Display.OpacityArrayName = ['POINTS', 'p']
clip2Display.ExtractedBlockIndex = 1
clip2Display.ScaleTransferFunction.Points = [375.79, 0.0, 0.5, 0.0, 556.30, 1.0, 0.5, 0.0]
clip2Display.OpacityTransferFunction.Points = [375.79, 0.0, 0.5, 0.0, 556.30, 1.0, 0.5, 0.0]
# hide data in view
Hide(clip1, renderView1)
clip2Display.SetScalarBarVisibility(renderView1, True)
clip3 = Clip(registrationName='Clip3', Input=clip2)
clip3.ClipType = 'Plane'
clip3.HyperTreeGridClipper = 'Plane'
clip3.Scalars = ['POINTS', 'p']
clip3.Value = 466.04
clip3.ClipType.Origin = [0.0, 0.0, 0.0065]
clip3.HyperTreeGridClipper.Origin = [0.0, 0.0, 0.0065]
# Properties modified on clip3
clip3.Invert = 0
# Properties modified on clip3.ClipType
clip3.ClipType.Origin = [0.0, 0.0, 0.0017]
clip3.ClipType.Normal = [0.0, 0.0, 1.0]
# show data in view
clip3Display = Show(clip3, renderView1, 'UnstructuredGridRepresentation')
clip3Display.Representation = 'Surface'
clip3Display.ColorArrayName = ['POINTS', 'p']
clip3Display.LookupTable = pLUT
clip3Display.SelectTCoordArray = 'None'
clip3Display.SelectNormalArray = 'None'
clip3Display.SelectTangentArray = 'None'
clip3Display.OSPRayScaleArray = 'p'
clip3Display.OSPRayScaleFunction = 'PiecewiseFunction'
clip3Display.SelectOrientationVectors = 'U'
clip3Display.ScaleFactor = 0.009
clip3Display.SelectScaleArray = 'p'
clip3Display.GlyphType = 'Arrow'
clip3Display.GlyphTableIndexArray = 'p'
clip3Display.GaussianRadius = 0.00045
clip3Display.SetScaleArray = ['POINTS', 'p']
clip3Display.ScaleTransferFunction = 'PiecewiseFunction'
clip3Display.OpacityArray = ['POINTS', 'p']
clip3Display.OpacityTransferFunction = 'PiecewiseFunction'
clip3Display.DataAxesGrid = 'GridAxesRepresentation'
clip3Display.PolarAxes = 'PolarAxesRepresentation'
clip3Display.ScalarOpacityFunction = pPWF
clip3Display.ScalarOpacityUnitDistance = 0.0017
clip3Display.OpacityArrayName = ['POINTS', 'p']
clip3Display.ExtractedBlockIndex = 1
clip3Display.ScaleTransferFunction.Points = [375.79, 0.0, 0.5, 0.0, 556.30, 1.0, 0.5, 0.0]
clip3Display.OpacityTransferFunction.Points = [375.79, 0.0, 0.5, 0.0, 556.30, 1.0, 0.5, 0.0]
# hide data in view
Hide(clip2, renderView1)
clip3Display.SetScalarBarVisibility(renderView1, True)
# create a new 'Iso Volume'
isoVolume1 = IsoVolume(registrationName='IsoVolume1', Input=clip3)
isoVolume1.InputScalars = ['POINTS', 'p']
isoVolume1.ThresholdRange = [375.79, 556.30]
# Properties modified on isoVolume1
isoVolume1.InputScalars = ['POINTS', 'alpha.water']
isoVolume1.ThresholdRange = [0.91, 1.0]
# show data in view
isoVolume1Display = Show(isoVolume1, renderView1, 'UnstructuredGridRepresentation')
isoVolume1Display.Representation = 'Surface'
isoVolume1Display.ColorArrayName = ['POINTS', 'p']
isoVolume1Display.LookupTable = pLUT
isoVolume1Display.SelectTCoordArray = 'None'
isoVolume1Display.SelectNormalArray = 'None'
isoVolume1Display.SelectTangentArray = 'None'
isoVolume1Display.OSPRayScaleArray = 'p'
isoVolume1Display.OSPRayScaleFunction = 'PiecewiseFunction'
isoVolume1Display.SelectOrientationVectors = 'U'
isoVolume1Display.ScaleFactor = 0.009
isoVolume1Display.SelectScaleArray = 'p'
isoVolume1Display.GlyphType = 'Arrow'
isoVolume1Display.GlyphTableIndexArray = 'p'
isoVolume1Display.GaussianRadius = 0.00045
isoVolume1Display.SetScaleArray = ['POINTS', 'p']
isoVolume1Display.ScaleTransferFunction = 'PiecewiseFunction'
isoVolume1Display.OpacityArray = ['POINTS', 'p']
isoVolume1Display.OpacityTransferFunction = 'PiecewiseFunction'
isoVolume1Display.DataAxesGrid = 'GridAxesRepresentation'
isoVolume1Display.PolarAxes = 'PolarAxesRepresentation'
isoVolume1Display.ScalarOpacityFunction = pPWF
isoVolume1Display.ScalarOpacityUnitDistance = 0.0048
isoVolume1Display.OpacityArrayName = ['POINTS', 'p']
isoVolume1Display.ExtractedBlockIndex = 1
isoVolume1Display.ScaleTransferFunction.Points = [375.79, 0.0, 0.5, 0.0, 554.07, 1.0, 0.5, 0.0]
isoVolume1Display.OpacityTransferFunction.Points = [375.79, 0.0, 0.5, 0.0, 554.07, 1.0, 0.5, 0.0]
# hide data in view
Hide(clip3, renderView1)
isoVolume1Display.SetScalarBarVisibility(renderView1, True)
# set scalar coloring
ColorBy(isoVolume1Display, ('POINTS', 'alpha.water'))
# Hide the scalar bar for this color map if no visible data is colored by it.
HideScalarBarIfNotNeeded(pLUT, renderView1)
# rescale color and/or opacity maps used to include current data range
isoVolume1Display.RescaleTransferFunctionToDataRange(True, False)
# get color transfer function/color map for 'alphawater'
alphawaterLUT = GetColorTransferFunction('alphawater')
# get opacity transfer function/opacity map for 'alphawater'
alphawaterPWF = GetOpacityTransferFunction('alphawater')
# create a new 'Integrate Variables'
integrateVariables1 = IntegrateVariables(registrationName='IntegrateVariables1', Input=isoVolume1)
# Create a new 'SpreadSheet View'
spreadSheetView1 = CreateView('SpreadSheetView')
spreadSheetView1.ColumnToSort = ''
spreadSheetView1.BlockSize = 1024
# show data in view
integrateVariables1Display = Show(integrateVariables1, spreadSheetView1, 'SpreadSheetRepresentation')
# get layout
layout1 = GetLayoutByName("Layout #1")
# add view to a layout so it's visible in UI
AssignViewToLayout(view=spreadSheetView1, layout=layout1, hint=0)
spreadSheetView1.Update()
# Properties modified on spreadSheetView1
spreadSheetView1.FieldAssociation = 'Cell Data'
spreadSheetView1.HiddenColumnLabels = []
spreadSheetView1.HiddenColumnLabels = ['Cell ID', 'Cell Type', 'UMean', 'UMean_Magnitude', 'UPrime2Mean', 'UPrime2Mean_Magnitude', 'U', 'U_Magnitude', 'pMean', 'pPrime2Mean', 'Block Number']
# set active source
SetActiveSource(integrateVariables1)
SelectIDs(IDs=[-1, 0], FieldType=0, ContainingCells=0)
# addendum: following script captures some of the application
# state to faithfully reproduce the visualization during playback
# saving layout sizes for layouts
# layout/tab size in pixels
layout1.SetSize(1079, 835)
# saving camera placements for views
# current camera placement for renderView1
renderView1.CameraPosition = [0.163, -0.067, -0.107]
renderView1.CameraFocalPoint = [0.0, 0.0, 0.0065]
renderView1.CameraViewUp = [0.137, 0.927, -0.35]
renderView1.CameraParallelScale = 0.054
# uncomment the following to render all views
# RenderAllViews()
# alternatively, if you want to write images, you can use SaveScreenshot(...).
What I want to do now is:
1.Get rid of all the graphical aspects of above mentioned python script and make it CLI basis (I run the script using Terminal and the output should takes place)
2.Later I want to ru nthe script using For loop for multiple ‘recorded time’ values for any case.
3.For each ‘recorded time’ the script should copy the alpha.water value and paste it in excel file.
Hence, with that in mind I changed the script as the following way:
Program_moded:
#!usr/bin/python
I = [20, 30, 40, 60, 70, 90]
J = [0001338, 0004013, 0009631, 0024078, 0033441]
for i in I:
for j in J:
a3D_Case20_halfGeom_70_FlR_0_0009631_WaterOpenFOAM = OpenFOAMReader(registrationName='3D_Case20_halfGeom_('I')_FlR_0_'J'_Water.OpenFOAM', FileName='3D_Case20_halfGeom_('I')_FlR_0_'J'_Water.OpenFOAM')
clip3.Invert = 0
# hide data in view
# show data in view
# get layout
# set active source
Result: Failure, Paraview sent out error, and crashed
Where did I go wrong?
How can I improve it?
Is there anyone having similar scripting idea?
