Hi there,
I’m in the process of upgrading tomviz to the latest ParaView.
Previously, we would read these cmake definitions to get the python dependencies:
ParaView_PYTHON_INCLUDE_DIR
ParaView_PYTHON_LIBRARY
ParaView_PYTHON_EXECUTABLE
But I see that they do not exist anymore. Is there a way to get these with the latest ParaView? We want to make sure we use the same python that ParaView does.
Patrick
The VTK::Python
target has the python library in use. It looks like we should probably export VTK_PYTHON_VERSION
or something like that from vtk-config.cmake
so that the executable can be found as well.
Do you know if I can get the python library and include directory into cmake variables by using get_target_property()
on VTK::Python
There’s a Python${VTK_PYTHON_VERSION}::Python
target. But since VTK_PYTHON_VERSION
is missing… Though Python${VTK_PYTHON_VERSION}_VERSION
should be in-scope.
Yeah, let’s just export VTK_PYTHON_VERSION
. That should allow everything to be accessible without having to spell it all out manually in VTK. Documentation should indicate how to get this.
Okay. Well, I got the cmake variables from the ParaView cache using the method on the right side here: https://github.com/OpenChemistry/tomviz/pull/1841/files#diff-af3b638bc2a3e6c650974192a53c7291R69
Let me know if there is a simpler way to do it.
That may be inaccurate. I recommend that if you’re asking ParaView’s build tree that you use PARAVIEW_PYTHON_VERSION
is set locally based on it. But, I recommend that that code disappear once VTK provides this variable.
