Paraview5.2.0-RC1 can be downloaded from the following address.
PVESSI can be downloaded at the following address.
I’m not sure if Tencent Cloud Server can be downloaded from other countries.
cmake -DPARAVIEW_USE_MPI=true -DPARAVIEW_ENABLE_PYTHON=true -DPARAVIEW_ENABLE_FFMPEG=true …
There were no errors in the configuration.
make -j 16
The errors during the make process are as follows: errors.md (42.4 KB)
I have already installed Real-ESSI locally and one example has run smoothly. I would like to see the results, but pvESSI has not been updated for 7-8.
I don’t know if it’s a network issue, but pvESSI is too old and I don’t have the confidence to compile successfully. I don’t know how to solve the above error. hi, Mathieu, Do you have time to take a walk?
