Description
When reading pvts file which is vtkXMLPStructuredGridWriter’s output, Paraview report error reading extent:
( 9.396s) [paraview ]vtkXMLStructuredDataRea:345 ERR| vtkXMLStructuredGridReader (0x1871ab50): Error reading extent 0 8 0 8 0 8 from piece 0
( 9.437s) [paraview ] vtkXMLDataReader.cxx:410 ERR| vtkXMLStructuredGridReader (0x1871ab50): Cannot read point data array "Velocity" from PointData in piece 0. The data array in the element may be too short.
( 9.437s) [paraview ] vtkXMLPDataReader.cxx:359 ERR| vtkXMLPStructuredGridReader (0x1b527920): Piece point data array Velocity not found
( 9.437s) [paraview ] vtkXMLPDataReader.cxx:359 ERR| vtkXMLPStructuredGridReader (0x1b527920): Piece point data array Pressure not found
Minimal reproduction is published to github.
https://github.com/CheapMeow/VTSWriter
Most of my code comes from https://stackoverflow.com/questions/24123432/composing-vtk-file-from-multiple-mpi-outputs, and his code run well. I don’t know what is the difference to make thing crashs.
File
my_vts_files.tar.gz (3.0 KB)
Env
Paraview Version
Client Information:
Version: 5.11.1
VTK Version: 9.2.20220823
Qt Version: 5.15.2
vtkIdType size: 64bits
Embedded Python: On
Python Library Path: /public/software/ParaView-5.11.1/lib/python3.9
Python Library Version: 3.9.13 (main, Mar 30 2023, 16:46:40) [GCC 7.3.1 20180303 (Red Hat 7.3.1-5)]
Python Numpy Support: On
Python Numpy Path: /public/software/ParaView-5.11.1/lib/python3.9/site-packages/numpy
Python Numpy Version: 1.21.1
Python Matplotlib Support: On
Python Matplotlib Path: /public/software/ParaView-5.11.1/lib/python3.9/site-packages/matplotlib
Python Testing: Off
MPI Enabled: On
ParaView Build ID: superbuild 2c64f06366aa320e98d98577af18bad64ad9a630 (!1076)
Disable Registry: Off
Test Directory:
Data Directory:
SMP Backend: TBB
SMP Max Number of Threads: 52
OpenGL Vendor: VMware, Inc.
OpenGL Version: 3.3 (Core Profile) Mesa 18.0.5
OpenGL Renderer: llvmpipe (LLVM 6.0, 256 bits)
Connection Information:
Remote Connection: No
VTK version I linked to: 9.1.0
Thank you for your reply!
