Hi all,
Sorry to bother, but my Paraview is running extremely slow on my workstation (ubuntu 20.04), to the point where the software just goes unresponded and I have to force quit. I tried reinstalling it to the newest version but it didn’t work.
Later I found in a similar post that the issue might have something to do with the OpenGL implementation (MESA vs. NVIDIA). I did the following check through googling. However, I still don’t know how to switch my OpenGL implementation from Mesa to NVIDIA.
mazq@Hogwarts:~/software/aspect/aspect/init/3Dmodel/output_20$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
mazq@Hogwarts:~/software/aspect/aspect/init/3Dmodel/output_20$ glxinfo -B
name of display: :1
display: :1 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Mesa/X.org (0xffffffff)
Device: llvmpipe (LLVM 12.0.0, 256 bits) (0xffffffff)
Version: 21.2.6
Accelerated: no
Video memory: 63950MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.5
Max compat profile version: 3.1
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
OpenGL vendor string: Mesa/X.org
OpenGL renderer string: llvmpipe (LLVM 12.0.0, 256 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 21.2.6
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 3.1 Mesa 21.2.6
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.2.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
mazq@Hogwarts:~/software/aspect/aspect/init/3Dmodel/output_20$ inix -G
Command 'inix' not found, did you mean:
command 'ninix' from deb ninix-aya (5.0.9-1)
command 'init' from deb systemd-sysv (245.4-4ubuntu3.22)
command 'inxi' from deb inxi (3.0.38-1-0ubuntu1)
Try: sudo apt install <deb name>
mazq@Hogwarts:~/software/aspect/aspect/init/3Dmodel/output_20$ sudo lshw -c display
*-display UNCLAIMED
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:b3:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list
configuration: latency=0
resources: memory:fa000000-faffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:f000(size=128) memory:fb000000-fb07ffff
mazq@Hogwarts:~/software/aspect/aspect/init/3Dmodel/output_20$ sudo prime-select
Usage: /usr/bin/prime-select nvidia|intel|on-demand|query
mazq@Hogwarts:~/software/aspect/aspect/init/3Dmodel/output_20$ sudo prime-select nvidia
Info: selecting the nvidia profile
Deleting /lib/modprobe.d/nvidia-runtimepm.conf
Updating the initramfs. Please wait for the operation to complete:
Done
mazq@Hogwarts:~/software/aspect/aspect/init/3Dmodel/output_20$ xorg.conf
xorg.conf: command not found
mazq@Hogwarts:~/software/aspect/aspect/init/3Dmodel/output_20$ ldconfig -p | grep GL
libvtkRenderingVolumeOpenGL2-pv5.7.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingVolumeOpenGL2-pv5.7.so.1
libvtkRenderingVolumeOpenGL2-pv5.7.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingVolumeOpenGL2-pv5.7.so
libvtkRenderingOpenGL2-pv5.7.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingOpenGL2-pv5.7.so.1
libvtkRenderingOpenGL2-pv5.7.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingOpenGL2-pv5.7.so
libvtkRenderingLICOpenGL2-pv5.7.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingLICOpenGL2-pv5.7.so.1
libvtkRenderingLICOpenGL2-pv5.7.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingLICOpenGL2-pv5.7.so
libvtkRenderingGL2PSOpenGL2-pv5.7.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingGL2PSOpenGL2-pv5.7.so.1
libvtkRenderingGL2PSOpenGL2-pv5.7.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingGL2PSOpenGL2-pv5.7.so
libvtkRenderingContextOpenGL2-pv5.7.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingContextOpenGL2-pv5.7.so.1
libvtkRenderingContextOpenGL2-pv5.7.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkRenderingContextOpenGL2-pv5.7.so
libvtkIceTGL-pv5.7.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkIceTGL-pv5.7.so.1
libvtkIceTGL-pv5.7.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkIceTGL-pv5.7.so
libvtkIOExportGL2PS-pv5.7.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkIOExportGL2PS-pv5.7.so.1
libvtkIOExportGL2PS-pv5.7.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libvtkIOExportGL2PS-pv5.7.so
libQt5OpenGL.so.5 (libc6,x86-64) => /lib/x86_64-linux-gnu/libQt5OpenGL.so.5
libQt5OpenGL.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libQt5OpenGL.so
libOpenGL.so.0 (libc6,x86-64) => /lib/x86_64-linux-gnu/libOpenGL.so.0
libOpenGL.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libOpenGL.so
libGLdispatch.so.0 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLdispatch.so.0
libGLdispatch.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLdispatch.so
libGLX_nvidia.so.0 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLX_nvidia.so.0
libGLX_nvidia.so.0 (libc6) => /lib/i386-linux-gnu/libGLX_nvidia.so.0
libGLX_mesa.so.0 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLX_mesa.so.0
libGLX.so.0 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLX.so.0
libGLX.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLX.so
libGLU.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLU.so.1
libGLU.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLU.so
libGLEW.so.2.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLEW.so.2.1
libGLESv2_nvidia.so.2 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLESv2_nvidia.so.2
libGLESv2_nvidia.so.2 (libc6) => /lib/i386-linux-gnu/libGLESv2_nvidia.so.2
libGLESv2.so.2 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLESv2.so.2
libGLESv2.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLESv2.so
libGLESv1_CM_nvidia.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLESv1_CM_nvidia.so.1
libGLESv1_CM_nvidia.so.1 (libc6) => /lib/i386-linux-gnu/libGLESv1_CM_nvidia.so.1
libGLESv1_CM.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLESv1_CM.so.1
libGLESv1_CM.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libGLESv1_CM.so
libGL.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libGL.so.1
libGL.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libGL.so
libEGL_nvidia.so.0 (libc6,x86-64) => /lib/x86_64-linux-gnu/libEGL_nvidia.so.0
libEGL_nvidia.so.0 (libc6) => /lib/i386-linux-gnu/libEGL_nvidia.so.0
libEGL_mesa.so.0 (libc6,x86-64) => /lib/x86_64-linux-gnu/libEGL_mesa.so.0
libEGL.so.1 (libc6,x86-64) => /lib/x86_64-linux-gnu/libEGL.so.1
libEGL.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libEGL.so
I would greatly appreciate it if someone could help me with this. Thank you!
Best regards,
Ziqi
