so me and my advisor wanted to ta save some scenes from MANY data. Basically I made a trace and it does the job for the data on my PC.
After running it through ssh with No-X I got this error:
<paraview.servermanager.XMLUnstructuredGridReader object at 0x2b3bc799c2e0>
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 155 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 66
Current serial number in output stream: 67
then I added -X, and even though I was able to do some other processes (cut data so its size is small), when it came to image output, I got this error:
( 71.382s) [main thread ]vtkXOpenGLRenderWindow.:451 ERR| vtkXOpenGLRenderWindow (0x564e23768ae0): bad X server connection. DISPLAY=:0. Aborting.
I’m pretty sure I should be able to run the Python Script without using ssh-X.
Has any of you any idea what to do next?
Should I install the headless paraview like I read in some similar probelm?
