I generated a dataset consisting of spheres with point data f and g. The data is provided below. It was loaded into ParaView in client/server mode. The server was initiated using pvserver without employing mpiexec.
Subsequently, the ‘Point Data to Cell Data’ filter was applied to generate cell data f and g. Following this, a selection was created based on the condition that cell data f > 500.
Currently, everything appears to be functioning correctly.
However, upon clicking to the next frame, the server abruptly terminated due to a segmentation fault:
[334221.884053] pvserver-real[1389068]: segfault at 0 ip 00007fc6e9bb8d42 sp 00007ffdfc61d690 error 4 in libvtkFiltersCore-pv5.12.so.1[7fc6e9877000+b74000]
[334221.884066] Code: c5 01 49 39 ec 0f 84 89 00 00 00 48 8b 84 24 10 01 00 00 48 8b 94 24 20 01 00 00 48 8b 80 38 01 00 00 48 8b 14 ea 48 8b 40 38 <48> 8b 34 d0 48 8b 84 24 58 01 00 00 48 8b 90 38 01 00 00 48 63 40
I’m uncertain about what occurred. Can someone assist in investigating this issue? Alternatively, could someone provide some guidance on resolving this error?
The server version is ParaView-5.12.0-egl-MPI-Linux-Python3.10-x86_64 download from the official website.
The server system is Ubuntu 22.04.4 LTS:
Linux 5.15.0-101-generic #111-Ubuntu SMP Tue Mar 5 20:16:58 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
Furthermore, I conducted local testing and confirmed that this error also occurs on the MacOS (arm64) version.
The data can be download here:
https://1drv.ms/u/s!Au1wcoQGYu6dlqI65wk6hXk8gQx1rw?e=kYZ7Sa
