For instance, I am using paraview 5.6.0 + mvapchi.
I’m confused on how running pvserver in parallel works. If I want to use 4 GPUs on a single machine,using MPI I will have to run 4 pvserver jobs using the parameters -display from 0.0 to 0.3 according to the given documentation
So far, this is what I got in the memory inspector:
However, when I execute the suggested Programmable Source to verify the processes on each display, I only get one ouput:
Which confuses me because I thought the first image confirmed the 4 jobs are working. My first guess on what happens is that I am running 4 cores and all of them are sharing the same GPU.
Also, If I connect to 2 machines with 4 GPUs each one:
I got the same output from the script
Do you guys have any thoughts? Is the given source code correct ? Have you guys test only with OpenMPI ?
Thank you for the help in advance
