I’m trying to obtain the points coordinates of a slice filter from OpenFOAM data without luck.
Here what I’ve tried so far
Extract data from a plane example (file is also attached) test_mpl.py (2.0 KB)
import os
import numpy as np
import matplotlib.pyplot as plt
from paraview.simple import *
from vtk.util import numpy_support as npvtk
def plane_points(plane_data, verbose=False):
“”"Extract the Cartesian points coordinates (x,y,z) of the triangulated plane
Parameters
plane_data: Paraview slice object
Return
x,y,z: arrays of floats
Cartesian coordinates of the points in the plane
# Get the number of points
nb_points = plane_data.GetNumberOfPoints()
# Put the points coordinates in x, y and z arrays
x_list = []
y_list = []
z_list = []
for i in range(nb_points):
coord = plane_data.GetPoint(i)
xx, yy, zz = coord[:3]
x_list.append(xx)
y_list.append(yy)
z_list.append(zz)
x = np.array(x_list)
y = np.array(y_list)
z = np.array(z_list)
# Display some information on the triangulation points
if verbose:
print("Number of points:", nb_points)
print("xrange: [{0:5.3f}, {1:5.3f}]".format(x.min(), x.max()))
print("yrange: [{0:5.3f}, {1:5.3f}]".format(y.min(), y.max()))
print("zrange: [{0:5.3f}, {1:5.3f}]".format(z.min(), z.max()))
# Return the points coordinates of the triangulated plane
return x, y, z
create a new ‘OpenFOAMReader’
pipeCyclicfoam = OpenFOAMReader(FileName=’./pipeCyclic/pipeCyclic.foam’)
pipeCyclicfoam.MeshRegions = [‘internalMesh’]
pipeCyclicfoam.CellArrays = [‘U’, ‘epsilon’, ‘k’, ‘nut’, ‘p’]
create a new ‘Slice’
slice1 = Slice(Input=pipeCyclicfoam)
slice1.SliceType = ‘Plane’
slice1.HyperTreeGridSlicer = ‘Plane’
slice1.SliceOffsetValues = [0.0]
Properties modified on slice1.SliceType
slice1.SliceType.Origin = [5.0, 0.0, 0.0]
slice1.SliceType.Normal = [1.0, 0.0, 0.0]
plane_data = servermanager.Fetch(slice1)
Extract the cartesian coordinates of the triangulation points
x,y,z = plane_points(plane_data, verbose=False)
I got this error message:
in plane_points(plane_data, verbose)
31
32 for i in range(nb_points):
---> 33 coord = plane_data.GetPoint(i)
34 xx, yy, zz = coord[:3]
35 x_list.append(xx)
AttributeError: 'vtkmodules.vtkCommonDataModel.vtkMultiBlockDataSet' object has no attribute 'GetPoint'
Any idea ?
I’m stuck
Many thanks !
