I have a situation in a simulation to show a slice of the same source but with different variable to be shown at different at different location in a view port..
[ Ex: imagine a propeller Right,Left , one to be shown as pressure the other density ]
The below workflow just copies the Reflect at same location again.. is there a way to decouple same slice, with same same source to be shown in different location in a view port .
Hi @cfd_payne !
Do you use multiviews in paraView ? With multiview you should be able to display different variable in each view, using the same source:
Yes, i know this feature exists
I’m trying to Augment reality on a background that has results to be displayed at two different location, simulation has only a symmetry modeled.
Can the scripts help here ?
Loading data set twice and ++transforms seems a quick workaround for what was needed within a single viewport.
