Paraview stops responding when loading large csv file
Are you building Paraview locally or just downloading the binary? If you’re building it you can increase the file size limit to 4Gb on Windows using the code change outlined here Error reading large VTK files in the Windows version - #22 by todoooo
Edit: Sorry that will only work for the XML reader.
You should be able to combine the tabular data inside Paraview.
