I’m getting a build issue with the PV 5.10 superbuild (using the V5.10.0 git tag) and gcc 7.3.0 and the following:
cmake -DBUILD_TESTING=OFF -DCMAKE_INSTALL_PREFIX=/app/DAAC/paraview/5.10.0_osmesa_intelmpi/ -DENABLE_python3=ON -DENABLE_osmesa=ON -DENABLE_openvdb=ON -DENABLE_mpi=ON -DENABLE_numpy=ON -DUSE_SYSTEM_mpi=ON -DSUPERBUILD_PROJECT_PARALLELISM=30 ../paraview-superbuild/
I’m hitting this on two separate systems. It looks to be failing in Cython with:
running build_ext
Error compiling Cython file:
object_expr = TypedExprNode(py_object_type, may_be_none=True)
# Fake rhs to silence "unused variable" warning
fake_rhs_expr = TypedExprNode(unspecified_type)
class ControlBlock(object):
Cython/Compiler/FlowControl.py:36:0: Compiler crash in AnalyseDeclarationsTransform
ModuleNode.body = StatListNode(FlowControl.py:1:0)
StatListNode.stats[14] = StatListNode(FlowControl.py:36:0)
StatListNode.stats[0] = CClassDefNode(FlowControl.py:36:0,
class_name = 'ControlBlock',
doc = "Control flow graph node. Sequence of assignments and name references.\n\n children set of children nodes\n parents set of parent nodes\n positions set of position markers\n\n stats list of block statements\n gen dict of assignments generated by this block\n bounded set of entries that are definitely bounded in this block\n\n Example:\n\n a = 1\n b = a + c # 'c' is already bounded or exception here\n\n stats = [Assignment(a), NameReference(a), NameReference(c),\n Assignment(b)]\n gen = {Entry(a): Assignment(a), Entry(b): Assignment(b)}\n bounded = set([Entry(a), Entry(c)])\n\n ",
visibility = 'private')
Compiler crash traceback from this point on:
File "/p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Compiler/Visitor.py", line 180, in _visit
return handler_method(obj)
File "/p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Compiler/ParseTreeTransforms.py", line 1636, in visit_CClassDefNode
self._inject_pickle_methods(node)
File "/p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Compiler/ParseTreeTransforms.py", line 1704, in _inject_pickle_methods
checksum = '0x%s' % hashlib.md5(' '.join(all_members_names).encode('utf-8')).hexdigest()[:7]
ValueError: [digital envelope routines: EVP_DigestInit_ex] disabled for fips
Compiling /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Plex/Scanners.py because it changed.
Compiling /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Plex/Actions.py because it changed.
Compiling /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Compiler/Scanning.py because it changed.
Compiling /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Compiler/Visitor.py because it changed.
Compiling /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Compiler/FlowControl.py because it changed.
Compiling /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Runtime/refnanny.pyx because it changed.
Compiling /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Compiler/FusedNode.py because it changed.
Compiling /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Tempita/_tempita.py because it changed.
[1/8] Cythonizing /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Compiler/FlowControl.py
File "/p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/setup.py", line 228, in <module>
setup(
File "/app/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/install/lib/python3.9/site-packages/setuptools/__init__.py", line 153, in setup
return distutils.core.setup(**attrs)
File "/app/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/install/lib/python3.9/distutils/core.py", line 148, in setup
dist.run_commands()
File "/app/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/install/lib/python3.9/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/app/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/install/lib/python3.9/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/app/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/install/lib/python3.9/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
File "/app/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/install/lib/python3.9/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
File "/app/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/install/lib/python3.9/distutils/dist.py", line 984, in run_command
cmd_obj.ensure_finalized()
File "/app/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/install/lib/python3.9/distutils/cmd.py", line 107, in ensure_finalized
self.finalize_options()
File "/p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Distutils/build_ext.py", line 20, in finalize_options
self.distribution.ext_modules[:] = cythonize(
File "/p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Build/Dependencies.py", line 1102, in cythonize
cythonize_one(*args)
File "/p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Build/Dependencies.py", line 1225, in cythonize_one
raise CompileError(None, pyx_file)
Cython.Compiler.Errors.CompileError: /p/home/apps/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/pythoncython/src/Cython/Compiler/FlowControl.py
CMake Error at /app/DAAC/paraview/5.10.0_osmesa_intelmpi_build/build/superbuild/sb-pythoncython-build.cmake:47 (message):
Failed with exit code 1
make[2]: *** [superbuild/pythoncython/stamp/pythoncython-build] Error 1
make[1]: *** [superbuild/CMakeFiles/pythoncython.dir/all] Error 2
make: *** [all] Error 2
Any ideas?
