I am trying to compile paraview on a P9 (ppc64le) machine (summit) with Optix and I get an error at install time - every compiled successfully. Strangely, the library where it fails dds.so seems to be a i86 library. @ben.boeckel Do you know anything about this.
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/libcudart.so.10.1 ==> lib
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/libdice.so ==> lib
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/libnvrtc.so.10.1 ==> lib
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/libnvindex.so ==> lib
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/libnvrtc-builtins.so ==> lib
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/libnvrtc-builtins.so.10.1 ==> lib
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/libnvindex_builtins.so ==> lib
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/liboptix.so.51 ==> lib
Creating symlink to lib/liboptix.so.51 ==> liboptix.so.5.1.2
No chrpath found; superbuild rpaths may still exist in the package
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/libVisRTX.so ==> lib
Copying /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/libVisRTX.so.0.1.6 ==> lib
WARNING: dependency from /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/dds.so to ld-linux-x86-64.so.2 requires a search path
CMake Error at cmake_install.cmake:728 (message):
  Failed to install dds.so:
  /sbin/ldconfig: Can't stat /usr/lib64/libglvnd: No such file or directory
  /sbin/ldconfig: Path `/usr/lib' given more than once
  /sbin/ldconfig: Path `/usr/lib64' given more than once
  /sbin/ldconfig: Cannot stat /lib64/libnvidia-fbc.so: No such file or
  directory
  /sbin/ldconfig: Cannot stat /lib64/libnvidia-ifr.so: No such file or
  directory
    File "/ccs/home/danlipsa/projects/paraview-superbuild/src-v5.9.0/superbuild/cmake/scripts/fixup_bundle.unix.py", line 750, in <module>
      main(sys.argv[1:])
    File "/ccs/home/danlipsa/projects/paraview-superbuild/src-v5.9.0/superbuild/cmake/scripts/fixup_bundle.unix.py", line 742, in main
      _install_binary(main_exe, is_excluded, bundle_dest, opts.libdir, installed, manifest, opts.source, dry_run=opts.dry_run, look_for_symlinks=opts.has_symlinks)
    File "/ccs/home/danlipsa/projects/paraview-superbuild/src-v5.9.0/superbuild/cmake/scripts/fixup_bundle.unix.py", line 601, in _install_binary
      deps = list(binary.dependencies.values())
    File "/ccs/home/danlipsa/projects/paraview-superbuild/src-v5.9.0/superbuild/cmake/scripts/fixup_bundle.unix.py", line 266, in dependencies
      deplib = Library.from_reference(dep, self)
    File "/ccs/home/danlipsa/projects/paraview-superbuild/src-v5.9.0/superbuild/cmake/scripts/fixup_bundle.unix.py", line 346, in from_reference
      raise RuntimeError('Unable to find the %s library from %s: %s' % (ref, loader.path, ', '.join(paths)))
  RuntimeError: Unable to find the ld-linux-x86-64.so.2 library from
  /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib/dds.so:
  /ccs/home/danlipsa/projects/paraview-superbuild/build-summit-egl-5.9.0/install/lib,
  /sw/summit/cuda/10.1.243/lib64,
  /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-7.4.0/spectrum-mpi-10.3.1.2-20200121-eu2wh5ypz6ipvokwbng2m5ihug6doysh/lib,
  /sw/summit/gcc/7.4.0/lib64,
  /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/darshan-runtime-3.1.7-cnvxicgf5j4ap64qi6v5gxp67hmrjz43/lib,
  /opt/ibm/spectrumcomputing/lsf/10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/lib,
  /opt/mellanox/hcoll/lib, /opt/ibutils/lib64,
  /opt/ibm/spectrum_mpi/jsm_pmix/lib, /opt/ibm/spectrum_mpi/lib,
  /usr/lib64/mysql, /opt/mellanox/mxm/lib, /opt/mellanox/sharp/lib, /lib,
  /lib64, /lib64/tls,
gmake[1]: *** [install] Error 1
CMake Error at superbuild/cmake_install.cmake:66 (message):
  Failed to install the paraviewsdk/TGZ package.
  cmake_install.cmake:47 (include)
make: *** [install] Error 1
