Dear community,
I have a problem that Paraview 5.5.2 throws bad_alloc and shuts down whenever I try to do a countour (iso-curves) of a slice of scalar data on a rather small unstructured 3D mesh. The message I get in the terminal is shown below. This happens almost every time. However, if I do the contour directly on the 3D data (iso-surfaces instead of iso-curves) there’s no bad_alloc. I run Arch Linux, and VTK 8.1.0. Do you have any ideas what may cause this and how to fix it?
Kind regards,
Sigvald
terminate called after throwing an instance of ‘std::bad_alloc’
what(): std::bad_alloc
[sim:11128] *** Process received signal ***
[sim:11128] Signal: Aborted (6)
[sim:11128] Signal code: (-6)
[sim:11128] [ 0] /usr/lib/libc.so.6(+0x37be0)[0x7fe831a03be0]
[sim:11128] [ 1] /usr/lib/libc.so.6(gsignal+0x10f)[0x7fe831a03b5f]
[sim:11128] [ 2] /usr/lib/libc.so.6(abort+0x125)[0x7fe8319ee452]
[sim:11128] [ 3] /usr/lib/libstdc++.so.6(+0x8958e)[0x7fe831c3358e]
[sim:11128] [ 4] /usr/lib/libstdc++.so.6(+0x8fdfa)[0x7fe831c39dfa]
[sim:11128] [ 5] /usr/lib/libstdc++.so.6(+0x8fe57)[0x7fe831c39e57]
[sim:11128] [ 6] /usr/lib/libstdc++.so.6(+0x900ac)[0x7fe831c3a0ac]
[sim:11128] [ 7] /usr/lib/libstdc++.so.6(+0x90647)[0x7fe831c3a647]
[sim:11128] [ 8] /usr/lib/libvtkCommonDataModel-pv5.5.so.1(_ZN15vtkPointLocator18InitPointInsertionEP9vtkPointsPKdx+0x211)[0x7fe82e2b7821]
[sim:11128] [ 9] /usr/lib/libvtkFiltersCore-pv5.5.so.1(ZN16vtkContourFilter11RequestDataEP14vtkInformationPP20vtkInformationVectorS3+0x4d8)[0x7fe8181dbd68]
[sim:11128] [10] /usr/lib/libvtkPVVTKExtensionsDefault-pv5.5.so.1(ZN18vtkPVContourFilter22ContourUsingSuperclassEP14vtkInformationPP20vtkInformationVectorS3+0x2b2)[0x7fe82995c6d2]
[sim:11128] [11] /usr/lib/libvtkPVVTKExtensionsDefault-pv5.5.so.1(ZN18vtkPVContourFilter11RequestDataEP14vtkInformationPP20vtkInformationVectorS3+0x279)[0x7fe82995c9b9]
[sim:11128] [12] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(ZN12vtkExecutive13CallAlgorithmEP14vtkInformationiPP20vtkInformationVectorS3+0x4e)[0x7fe82b67043e]
[sim:11128] [13] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(ZN23vtkDemandDrivenPipeline11ExecuteDataEP14vtkInformationPP20vtkInformationVectorS3+0x37)[0x7fe82b669df7]
[sim:11128] [14] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(ZN24vtkCompositeDataPipeline11ExecuteDataEP14vtkInformationPP20vtkInformationVectorS3+0x9a)[0x7fe82b666a1a]
[sim:11128] [15] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(ZN23vtkDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x3f6)[0x7fe82b66ce06]
[sim:11128] [16] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(ZN32vtkStreamingDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x1bc)[0x7fe82b68dd1c]
[sim:11128] [17] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(_ZN24vtkCompositeDataPipeline15ForwardUpstreamEP14vtkInformation+0x189)[0x7fe82b6659c9]
[sim:11128] [18] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(ZN23vtkDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x234)[0x7fe82b66cc44]
[sim:11128] [19] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(ZN32vtkStreamingDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x1bc)[0x7fe82b68dd1c]
[sim:11128] [20] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(_ZN23vtkDemandDrivenPipeline10UpdateDataEi+0x1f9)[0x7fe82b66b739]
[sim:11128] [21] /usr/lib/libvtkCommonExecutionModel-pv5.5.so.1(_ZN32vtkStreamingDemandDrivenPipeline6UpdateEiP20vtkInformationVector+0x123)[0x7fe82b68f223]
[sim:11128] [22] /usr/lib/libvtkPVServerManagerApplication-pv5.5.so.1(_Z23vtkSISourceProxyCommandP26vtkClientServerInterpreterP13vtkObjectBasePKcRK21vtkClientServerStreamRS5_Pv+0x6cf)[0x7fe8309d394f]
[sim:11128] [23] /usr/lib/libvtkClientServer-pv5.5.so.1(ZN26vtkClientServerInterpreter19CallCommandFunctionEPKcP13vtkObjectBaseS1_RK21vtkClientServerStreamRS4+0x1f0)[0x7fe82a15e780]
[sim:11128] [24] /usr/lib/libvtkClientServer-pv5.5.so.1(_ZN26vtkClientServerInterpreter20ProcessCommandInvokeERK21vtkClientServerStreami+0x49f)[0x7fe82a15ee1f]
[sim:11128] [25] /usr/lib/libvtkClientServer-pv5.5.so.1(_ZN26vtkClientServerInterpreter17ProcessOneMessageERK21vtkClientServerStreami+0x46f)[0x7fe82a15f2ef]
[sim:11128] [26] /usr/lib/libvtkClientServer-pv5.5.so.1(_ZN26vtkClientServerInterpreter13ProcessStreamERK21vtkClientServerStream+0x1e)[0x7fe82a15f3be]
[sim:11128] [27] /usr/lib/libvtkPVServerImplementationCore-pv5.5.so.1(_ZN16vtkPVSessionCore21ExecuteStreamInternalERK21vtkClientServerStreamb+0xff)[0x7fe82f05e9df]
[sim:11128] [28] /usr/lib/libvtkPVServerImplementationCore-pv5.5.so.1(_ZN16vtkPVSessionCore13ExecuteStreamEjRK21vtkClientServerStreamb+0x4c)[0x7fe82f05e7fc]
[sim:11128] [29] /usr/lib/libvtkPVServerImplementationCore-pv5.5.so.1(_ZN16vtkPVSessionBase13ExecuteStreamEjRK21vtkClientServerStreamb+0x35)[0x7fe82f05d3a5]
[sim:11128] *** End of error message ***
[1] 11128 abort (core dumped) paraview sheath.pvsm
