I am using Paraview Visualizer web application on my local machine to open around 60 vtk data files. I am able to open it without any problem.
Now I want to save it as animation .avi file. I can do that in paraview desktop application but same thing is not possible in paraview web visualizer , it just allows us to save state in png format.
How to save the animation from Visualizer ?
Even i tried to load plugins as per below documentation but unable to see any plugins in visualizer web app.
–plugins Colon-separated (’:’) list of fully qualified path names to plugin objects to load.
is this functionality supported in Visualizer ? can we extend it through Plugin ?
from Visualizer I just want to call (paraview 5.7)SaveAnimation command for the active scene, for this do in need to write plugin ?
I saw LeagacyVTK reader is added to proxies.json in Visualizer code
in similar way can SaveAnimation command be added to proxies.json ? and we can call it directly from visualizer UI
Even I tried to create plugin for save animation but it fails in loading giving error in register_plugin command.
Do I need to create .xml file as well for my plugin?
Please guide.
I feel like saveanimation is part of paraview command and i can directly call it from visualizer? is it possible ?
please suggest me any example which I can follow to implement this.
I could save animation now from Visualizer. Thanks for your suggestion.
I want to put Visualizer on AWS , ec2, As per suggestion I created new protocol. I want to put this whole solution on cloud (EC2).
For visualizer any paid setup is available on EC2 ? , so that we can call it directly.
OR
If I have to use Docker image here? I want to use Paraview 5.7 here.
Basically I want to start Visualizer on my client machine and my Paraview Web Server on Cloud EC2 instance , Please guide me what is the best way to achieve this.
