Hi, I’ve been trying to build Paraview by following the guides here and here, however, I have run into some issues when attempting both ways. I’ve followed the Windows dependencies, having installed the appropriate versions of CMake, VS2015, ninja-build, the Microsoft MPI files, Python for Windows, and Qt 5.12.3 with the MSVC 2015 component installed, and the appropriate additions to the PATH environment variable.
I believe I have obtained the proper source, having cloned the repository using:
git clone --recursive https://gitlab.kitware.com/paraview/paraview.git
I then run the following in VS2015 x64 Native Tools Command Prompt:
cd C:\pv\pvb
cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=OpenMP -DCMAKE_BUILD_TYPE=Release …\pv
ninja
After a while, I get a long string of syntax errors that I have attached to this post. Does anyone have any suggestions? I’ve tried building with VS2015 but also eventually run into these syntax errors which cause the build to fail.
