paraview without resources
i did get the paraview code source and build it, but when i execute the generated ‘paraview.exe’ it doesn’t show the resources (images and icons) like in the screen below
is there any missing ressouces of files that i should put them in the output folder.
thanks in advance for your helps.
regards
Hi @may_soun
You need to install the Qt svg package. Using ubuntu that would be:
sudo apt-get install libqt5svg5*
thank you for your response, but i’m using windows, how can i install it
How did you install Qt ?
but i have already the Qt5svg in the Qt folder installation
i did copy the Qt5Svg.dll in the same location of “paraview.exe” but still the same issue
I’m afraid I have no idea. The symptom you have looks like svg component of Qt is not available.
