Hello I have been using ParaView to process OpenFOAM data since April. Today out of nowhere the app stopped loading on me. Any time I opened I would just get a blank screen. I ended up uninstalling the version I had and installed 5.8.1.
The GUI isn’t blank, but I can not load my mesh. I can go to file and select the .foam file I want to open. But after that, the application completely freezes on me. Whenever I try to toggle the “eye” in the pipeline browser just ignores my request.
I’m going to take a wild guess that you have a bad configuration file, since it worked before, I assume you have not messed with anything, and now it’s broken.
Delete your configuration files. Run ParaView. Edit/ Reset to Default Settings. Please save a copy. Exit ParaView, restart again.
After reading this thoroughly I realized my issue was because I was trying to open the results on a new monitor I had connected to to my laptop using an HDMI to USB 3 adapter.
Once I moved the window over to my laptop the data loaded fine.
