Paraviewweb docker issue
I am trying to setup paraviewweb inside a docker container. I have followed this tutorial Kitware/paraviewweb-demo: Website and launcher for ParaViewWeb container demo (github.com), the osmesa version and using the kitware/paraview:pvw-v5.7.1-osmesa-py3 image.
When I start the container I can see the 4 application (Visualizer, Divvy, Lite and Glance) but if I try and connect to Lite for example I get a “Connection closed before receiving a handshake response” error or for Visualizer & Divvy I get “Session did not start before timeout expired. Check session logs.”
Also I have checked the logs found at
/pvw/launcher/logs
and they all say the following:
Presets were imported successfully
wslink: Starting factory
CRITICAL:twisted:wslink: Starting factory
I have not modified anything yet this happened on a fresh container.
Does anyone know what the issue might be.
Thanks.
I’m not sure what could be happening. But you may want to use an image younger than four years old.
I would use a trame based image and setup ParaView 5.11 either by mounting it or bundling it within your image.
HTH,
Seb
Would using the Trame docker image still allow me to use Paraview-lite through a launcher config?
yes, the core infrastructure is exactly the same
