Hi
I’m looking for a way to plot the particle density of a simulation along a single dimension. Basically a histogram of the y-coordinates. At a first glance the histogram filter looks just like the thing I need, however, it only lets me use the particle properties as input but not the particle coordinates. What do I have to do pass the y-coordinates to this filter? Or do I have to use a different one?
Here is a dummy version of my data files to show their layout:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<VTKFile byte_order="LittleEndian" type="UnstructuredGrid" version="0.1">
<UnstructuredGrid>
<Piece NumberOfCells="0" NumberOfPoints="2">
<PointData>
<DataArray Name="PropA" NumberOfComponents="1" format="ascii" type="Int32">0 1</DataArray>
<DataArray Name="PropB" NumberOfComponents="1" format="ascii" type="Int32">2 3</DataArray>
</PointData>
<CellData/>
<Points>
<DataArray Name="points" NumberOfComponents="3" format="ascii" type="Float32">0.0 0.0 0.0 1.0 1.0 1.0</DataArray>
</Points>
<Cells>
<DataArray Name="types" NumberOfComponents="0" format="ascii" type="Float32"/>
</Cells>
</Piece>
</UnstructuredGrid>
</VTKFile>
