to visualize a very large dataset in a reasonable amount of time I partitioned the original XDMF file in a way that each MPI process can load a part of the data. This is the structure of the file:
<?xml version="1.0" ?>
<!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" []>
<Xdmf Version="2.0">
<Domain>
<DataItem NumberType="UInt" Precision="4" Format="HDF" Dimensions="48542797">sumatra_compressed.h5:/partition</DataItem>
<DataItem NumberType="Float" Precision="4" Format="HDF" Dimensions=" 101 48542797">sumatra_compressed.h5:/u</DataItem>
<DataItem NumberType="Float" Precision="4" Format="HDF" Dimensions=" 101 48542797">sumatra_compressed.h5:/v</DataItem>
<DataItem NumberType="Float" Precision="4" Format="HDF" Dimensions=" 101 48542797">sumatra_compressed.h5:/w</DataItem>
<Grid Name="TimeSeries" GridType="Collection" CollectionType="Temporal">
<Grid Name="SpaceSeries" GridType="Collection" CollectionType="Spatial">
<Grid Name="step_000000000050_p0" GridType="Uniform">
<Topology TopologyType="Tetrahedron" NumberOfElements="108355">
<DataItem ItemType="HyperSlab" Dimensions="108355 4">
<DataItem NumberType="UInt" Precision="8" Format="XML" Dimensions="3 2">0 0 1 1 108355 4</DataItem>
<DataItem NumberType="Int" Precision="8" Format="HDF" Dimensions="48542797 4">sumatra_compressed.h5:/connect</DataItem>
</DataItem>
</Topology>
<Geometry GeometryType="XYZ" NumberOfElements="8400027">
<DataItem NumberType="Float" Precision="4" Format="HDF" Dimensions="8400027 3">sumatra_compressed.h5:/geometry</DataItem>
</Geometry>
<Time Value="250"/>
<Attribute Name="u" Center="Cell">
<DataItem ItemType="HyperSlab" Dimensions="108355">
<DataItem NumberType="UInt" Precision="8" Format="XML" Dimensions="3 2">50 0 1 1 1 108355</DataItem>
<DataItem Reference="/Xdmf/Domain/DataItem[2]"/>
</DataItem>
</Attribute>
<Attribute Name="v" Center="Cell">
<DataItem Reference="/Xdmf/Domain/DataItem[3]"/>
</DataItem>
</Attribute>
<Attribute Name="w" Center="Cell">
<DataItem Reference="/Xdmf/Domain/DataItem[4]"/>
</DataItem>
</Attribute>
</Grid>
<Grid Name="step_000000000050_p1" GridType="Uniform">
<Grid Name="step_000000000050_p447" GridType="Uniform">
whereas the _p0 stands for “process 0”. This works quite well, as I can also just select a subset of all partitions and paraview shows them correctly. The only problem I am encountering is that although the data is partitioned, each MPI process reads the complete timestep instead of the specific part of the timestep. This causes memory problems as one timestep is getting big. This is the reason why I can’t use D3 in that case - the memory footprint is much too high.
It seems as this is a bug - or am I doing something wrong?
I am using paraview 5.2.0, which is the latest version running on our cluster as 5.5.0 is not supported yet.
Thanks in advance and regards
Chris
