ValeRomano
(Valentina Romano)
November 2, 2020, 5:07pm
#1
I have a dataset in hd5 format from my simulation with Pflotran.
I’d like to know if it is possible to extract the data as a function of time in a specific point of the model domain.
I saw that there is a filter to do this for other data formats.
Thank you,
Best
Valentina
mwestphal
(Mathieu Westphal (Kitware))
November 4, 2020, 8:33am
#2
ForceTime filter ?
If you can read your data in ParaView, you can process it as any other format.
ValeRomano
(Valentina Romano)
November 4, 2020, 8:41am
#3
Hi Mathieu,
yes I can definitely open the file, but I tried to use the same routine as in this tutorial, but I cannot get a result. Any suggestion?
Plot point over time
Edit → Reset Session.
Open can.exo. Turn on all data. Apply .
Drag the can around with the left mouse button until you can see the can.
We want to plot a point over time. First, we need to select a point.
Click on Select Points On icon. Then, click on a point on the can.
Filters→Data Analysis→Plot Point Over Time . Apply.
Display tab, unselect everything other than DISPL (Magnitude)
You now have a plot of the displacement. at your point.
Extra Credit – Using Select Cells On icon, and the Plot Cell Over Time , plot EQPS over time.
Thank you,
Valentina
mwestphal
November 4, 2020, 2:22pm
#4
Plot over time should work.
Could you share your data ?
ValeRomano
(Valentina Romano)
November 4, 2020, 4:34pm
#5
Hi Mathew,
here is one of the files:
Thank you for your help,
Valentina
mwestphal
November 6, 2020, 11:30am
#6
Plot data over time works with your dataset:
ValeRomano
(Valentina Romano)
November 6, 2020, 11:43am
#7
Hi Mathieu,
Sounds great, how did you get that?
I couldn’t make it with that procedure
Thanks a lot,
Vale
Valentina Romano, PhD
Earth Sciences Department
Sapienza University of Rome
