I could make a vtk file with corresponding coordinates, but I would have thought that paraview should already have options to do this manipulation. Any ideas will be helpful.
the middle point of the glyph will be the nodal point of the mesh, which is the desired outcome. If the first component of the Center option is set to 0.5, the starting point of the glyph will align with the nodal point of the mesh.
I’m facing a similar problem, trying to put the arrows with their heads on the nodes. However, I cannot find the options for “Glyph Source” that you proposed in my Properties window. There’s only one Glyph Type selectable and no Center option.
