Hello.
I am trying to create multiple slices along tube-like geometries.
If I use the standard slice filter, the plane cuts across the entire domain like this:
This results in two slices. I don’t want this:
Instead I want a series of slices like this:
The problem is, using the slice + clip function is very time-intensive and I was wondering if there is a better way. For example, defining a plane with a point, normal and radius. Or defining a plane with 3 points. I also have a polyline (centerline) which might be useful for this process.
Currently, I need to apply slice + clip manually which is slow for many cross-sections and geometries.
Any advice is greatly appreciated.
