Plot a simple XY chart
I want to draw a simple line chart with Paraview. It is a simple XY plot. My input data is something like
X Y
0 0
1 1
2 1.4142
4 2
I would like to store this data in a file with a format that paraview can read and generate a simple plot like this.
I would like to know what the file type and required format should be. Any help would be appreciated
The simple way to go is with a csv file.
  • Open ParaView
  • Open your csv file
  • Set separator to " "
  • Apply
  • Create a new view, Line Chart View
  • Show your file in the view
  • In Series Parameters, check “Y”
Thanks a lot! It worked out!
I am curious whether one can instruct Paraview to connect the discrete data points with line types other than a straight line. In Tecplot, for example, I can visualize this plot using different line styles
line segment
Polynomial fit
Spline
Different interpolation methods for plots are not supported to my knowledge.
This question is close to my requirement. But I still have a question about how to draw a x-y curve with point data imported by vtk file. As shown below I can only draw time-y curve or x-y curve with avg/max/q3/std values at a frame. They are neither x-y curve with all frame data. I post the data file also.
Thanks if anyone can help!
data.zip (4.8 KB)
Try unchecking Only Report Selection Statistics.
