As you can see above, the line overlap one another in a funny way, which makes the visualisation really difficult. I had the issue on three different computer and I’m currently using 5.7.
Here are the XDMF files I’m using.
To reproduce the bug, simply load the xdmf file, then PlotOverLine (any direction) and click Play. files.zip (2.8 MB)
I had the issue on three different machines so I reckon it’s either a bug or something I do wrong (more likely). Here’s a video of what I see: capture_.zip (2.6 MB)
@mwestphal, I also tried and nor do I get the errant behavior (Windows 10 with an old Quadro K4200). Sounds like a graphics driver issue. Weird that you would same the same behavior on two different OS’s though.
@Rem, What happens if in the properties for the line chart view you set Left Axis Use Custom Range? It might also be helpful to update the graphics driver.
@Kenneth_Moreland in fact it was on 3 different computers. One had RX 480 + Intel i5 the other GeForce GTX 150 Ti + Intel i7 (both Windows 10)
The problem is still here when setting Custom Range :
Nope didn’t do the trick.
It seems that the window is zooming in and immediately zooming out at each time step which makes this clipping effect (see attached video).2019-12-20 09-55-34.rar (1.3 MB)
hi all, don’t know if this bug (if it is indeed one) has been further investigated or not… I updated all my drviers and all but still no improvement. I forgot to mention that while playing the animation, I can encounter this kind of issue (see picture). The window goes back to normal if the cursor to it. Does that give any hint ?
