Plot Over Line
Is there any way that in a ‘Plot Over Line’ tool, the X axis is changed into Y axis?
In the graph above by the Plot Over Line, the X axis represents Z (the height of geometry 0-0.9m) and the Y axis shows U Magnitude.
However, I would represent:
X = U Magnitude
Y = The height (m)
How can I change it?
Please help.
Thanks!
Go to the Display properties in the properties panel. Change the X Array Name parameter to what you want to represent the x axis (in this case, U magnitude). Then go to the Series Parameters table. Turn off all series and then turn on arc_length.
That works.
Thanks, Kenneth!
