Plot question
Hello All,
Hope you’re doing well! I am responding here because I have a follow-up question. I am trying to use respectively “Plot On Sorted Line” and “Plot On Intersection Curves” to plot on specific line surroundig a bubble. However for any of these filter, the data are plotted randomly and Paraview doesn’t follow the path of the line. How can I sort this issue ?
I tried to use clean filter but my case freezes each time I am using it ):
I am using a high defined mesh with a .foam file, if it is helpful.
Hope someone can help me,
Thanks for your time!
Sincerely,
Santhosh
Please share data and steps to reproduc e
Hello Mathieu,
thanks for the fast reply! I actually found a solution, which is to organize data according to points magnitude value.
I was going according to arc_length magnitude before which was leading to random points follow.
