Hi all,
how to plot the pressure curves in functions of the angle (0 to 360) over a cylinder. the study is a numerical simulation of a turbulent flow around four cylinders in square configuration, I used Gmsh for geometry and mesh generation , then Code_Saturne for the calculation.
You will have to compute the angle first. Could you do that befoehand ?
in the solver or in ParaView ?
in your solver.
This should be doable in ParaView, but will require some computation and knowledge about the cylinder that you must already have in your solver.
