Dear ParaView community,
I’m trying to read a Plot3D file into ParaView. I have the grid file (.x) and the code I have access to writes out the function file containing the solution data (.f). The files are binary, little endian, double-precision, written by Fortran code and have a blanking variable set.
Now, reading the grid file only (without any solution file or function file attached) works fine. The issue comes when I try to add the solution or function file. I tried circumventing the problem by using vtk directly, but I am still unable to read the files, it reports the two files have a different number of zones, which I know is not correct since I can open the files with no issues in other software, Tecplot for example.
Here’s the piece of vtk code I wrote to load the file, for reference.
reader = vtk.vtkMultiBlockPLOT3DReader()
reader.SetXYZFileName(‘test.x’)
reader.SetQFileName(‘test.q’)
reader.AutoDetectFormatOff()
reader.BinaryFileOn()
reader.MultiGridOn()
reader.HasByteCountOn()
reader.IBlankingOn()
reader.DoublePrecisionOn()
reader.SetByteOrderToLittleEndian()
reader.Update()
Is this a known bug, or is there something else I should try?
