Plugin XML constraints
Hello!
I have found the email about that properties names in XML should be unique
https://public.kitware.com/pipermail/paraview/2012-June/025222.html
However I am interested, whether or not they can repeat on different depths of xml nested.
			<DoubleVectorProperty
				<Hints>
					<PropertyWidgetDecorator type="EnableWidgetDecorator">
						<Property name="Enable Advanced" function="boolean" />
					</PropertyWidgetDecorator>
				</Hints>
			</DoubleVectorProperty>
				<Hints>
				</Hints>
Or will <Property name= repeating cause a failure?
Thanks
It will not, this is fine and just pointing to the same property
Thank you a lot Mathieu!
