Poor performance for high number of timesteps
Hello! I am new to ParaView/Vtk and am looking for some guidance. Currently I am testing vtk-xmlUnstructuredGrids as a possible output format for a project. I tested the following sets in the paraview Render-View:
  • 7000 cells / 100 Time steps —> 25 Fps
  • 6 cells / 32 000 Time steps —> 2Fps
Is there an obvious reason for this performance drop? Should I use a different vtk File Format? Can I improve the ParaView performance apart from activating animation cache?
Thanks a lot in advance!
Hi @SchnFlo.
Welcome to the ParaView community!
Which version of ParaView and which operating system are you using?
Thank you for the fast reply!
I tested the set on two configurations :
  • Arch Linux (Workstation)
    • ParaView 5.11.2
    • Ryzen 1700x
    • AMD Radeon RX5700 XT (Mesa Drivers)
  • Windows 11(Mobile)
    • ParaView 5.12
    • Ryzen 4600H
    • AMD Radeon RX 640
The above mentioned benchmarks were created on the workstation. The poor performance can be seen on both configurations.
could you share that data ?
Of course! You can find the two data sets here.
I confirm that there is a significant performance difference caused by the number of timesteps.
FYI @nicolas.vuaille
@SchnFlo could you open an issue ?
https://gitlab.kitware.com/paraview/paraview/-/issues
FYI, I was also able to reproduce from paraview application, but not from pvpython. So it is more probably a GUI-related issue.
Please post the link to the issue in git here. I will fund it.
git issue. Thank you!
