Problem compiling OSMesa as part of ParaView 5.10.0-RC1 on Power 9 Architecture
I am having an issue compiling OSMesa as part of ParaView 5.10.0-RC1 on a Power 9 Architecture System.
Even though I am using
-Dmesa_USE_SWR=OFF \
It still seems to be tryng to compile SWR which requires AVX, but as AVX instructions do not exist on the Power 9 Architecture this fails.
Here is the end of the file
Build_directory/superbuild/osmesa/src/build/meson-logs/meson-log.txt
showing the error.
Compiler stdout:
Compiler stderr:
 g++: error: unrecognized command-line option '-mavx'
Compiler for C++ supports arguments -mavx: NO
Running compile:
Working directory:  /p/app/DAAC/build/PV/Build_5.10.0-RC1_osmesa_openmpi_411_gcc_1021/superbuild/osmesa/src/build/meson-private/tmpds97ckla
Command line:  /opt/rh/gcc-toolset-10/root/usr/bin/g++ /p/app/DAAC/build/PV/Build_5.10.0-RC1_osmesa_openmpi_411_gcc_1021/superbuild/osmesa/src/build/meson-private/tmpds97ckla/testfile.cpp -o /p/app/DAAC/build/PV/Build_5.10.0-RC1_osmesa_openmpi_411_gcc_1021/superbuild/osmesa/src/build/meson-private/tmpds97ckla/output.obj -c -fPIC -D_FILE_OFFSET_BITS=64 -O0 -fpermissive -march=core-avx
Code:
 extern int i;
int i;
Compiler stdout:
Compiler stderr:
 g++: error: unrecognized command-line option '-march=core-avx'
Compiler for C++ supports arguments -march=core-avx: NO
Running compile:
Working directory:  /p/app/DAAC/build/PV/Build_5.10.0-RC1_osmesa_openmpi_411_gcc_1021/superbuild/osmesa/src/build/meson-private/tmpzrhyptjy
Command line:  /opt/rh/gcc-toolset-10/root/usr/bin/g++ /p/app/DAAC/build/PV/Build_5.10.0-RC1_osmesa_openmpi_411_gcc_1021/superbuild/osmesa/src/build/meson-private/tmpzrhyptjy/testfile.cpp -o /p/app/DAAC/build/PV/Build_5.10.0-RC1_osmesa_openmpi_411_gcc_1021/superbuild/osmesa/src/build/meson-private/tmpzrhyptjy/output.obj -c -fPIC -D_FILE_OFFSET_BITS=64 -O0 -fpermissive -tp=sandybridge
Code:
 extern int i;
int i;
Compiler stdout:
Compiler stderr:
 g++: error: unrecognized command-line option '-tp=sandybridge'
Compiler for C++ supports arguments -tp=sandybridge: NO
Running compile:
Working directory:  /p/app/DAAC/build/PV/Build_5.10.0-RC1_osmesa_openmpi_411_gcc_1021/superbuild/osmesa/src/build/meson-private/tmp_x5lkzj9
Command line:  /opt/rh/gcc-toolset-10/root/usr/bin/g++ /p/app/DAAC/build/PV/Build_5.10.0-RC1_osmesa_openmpi_411_gcc_1021/superbuild/osmesa/src/build/meson-private/tmp_x5lkzj9/testfile.cpp -o /p/app/DAAC/build/PV/Build_5.10.0-RC1_osmesa_openmpi_411_gcc_1021/superbuild/osmesa/src/build/meson-private/tmp_x5lkzj9/output.obj -c -fPIC -D_FILE_OFFSET_BITS=64 -O0 -fpermissive /arch:AVX
Code:
 extern int i;
int i;
Compiler stdout:
Compiler stderr:
 g++: error: /arch:AVX: No such file or directory
Compiler for C++ supports arguments /arch:AVX: NO
First supported argument: None
src/gallium/drivers/swr/meson.build:207:2: ERROR: Problem encountered: Cannot find AVX support for swr. (these are required for SWR an all architectures.)
Thanks,
Joe
@ben.boeckel
Joe,
I believe this is the one Ben found for me. It is broken in RC1, I believe master Superbuild is good, I believe RC2 will be fixed. RC2 lands in a week’ish.
Alan,
Thanks, for letting me know that this has been fixed.
I will be sure to test RC2 and/or the master Superbuild.
Hopefully the Mesa build is fixed as well, which has similar issues.
Joe
Alan and Ben,
I can confirm the patch works for the OSMesa version, the Mesa version still has issues, as I have reported in similar topic.
https://discourse.paraview.org/t/problem-compiling-mesa-as-part-of-superbuild-of-paraview-5-10-0-rc1-on-power-9-architecture/8254
Thanks,
Joe
