Dear all,
I’m trying to start pvserver on a certain amount of cores on my desktop computer using servers.pvsc file. I tried both the direct and the reverse connection strategy but could not find a way to let it work.
This is how my servers.pvsc looks like:
<Servers> <Server name="DESKTOPMACHINE - REVERSE" resource="csrc://localhost"> <CommandStartup> <Options> <Option name="PV_CONNECT_ID" label="Connect ID" readonly="true"> <Range type="int" min="1" max="65535" step="1" default="random"/> </Option> <Option name="NPROC" label="Number of Processors:"> <Range type="int" min="1" max="8" step="1" default="4"/> </Option> </Options> <Command exec="/usr/bin/mpirun -np $NPROC$ /opt/paraview_v5.8.0/bin/pvserver" delay="5" timeout="60"> <Arguments> <Argument value="-rc"/> <Argument value="-ch=desktopMachineName"/> <Argument value="--connect-id=$PV_CONNECT_ID$"/> </Arguments> </Command> </CommandStartup> </Server> <Server name="DESKTOPMACHINE" resource="cs://localhost"> <CommandStartup> <Options> <Option name="PV_CONNECT_ID" label="Connect ID" readonly="true"> <Range type="int" min="1" max="65535" step="1" default="random"/> </Option> <Option name="NPROC" label="Number of Processors:"> <Range type="int" min="1" max="8" step="1" default="4"/> </Option> </Options> <Command exec="/usr/bin/mpirun -np $NPROC$ /opt/paraview_v5.8.0/bin/pvserver" delay="5" timeout="60"> <Arguments> <Argument value="--connect-id=$PV_CONNECT_ID$"/> </Arguments> </Command> </CommandStartup> </Server> </Servers>
On the client dialog box, when connecting, no messages appear except “Command aborted.”
The previously mentioned server settings work when I remove the mpirun -np NPROCS part from the exec command.
Any idea about how to fix this?
Thanks in advance,
Lorenzo
