Hi all,
is there a way to use a value computed with a programmable filter within a trace. As a kind of a return value.
Thanks in advance
Darius
Hi all,
Thanks in advance
Darius
Not sure to follow here, can you elaborate.
I’d like to calculate a scalar value with the help of a programmable filter inside of a trace/macro script, in order to scale a Glyph object, that is created in the “outer” trace/macro script after the programmableFilter-object.
It may seem as an obnoxious workaround, since I did not find a way to fetch DataArrays in the trace/macro script, without using a ProgrammableFilter.
