Hey everyone,
I am having a problem with a generated python script in paraview. The script is auto-generated using the trace functionality.
This is the script:
# trace generated using paraview version 5.10.0-RC1
#import paraview
#paraview.compatibility.major = 5
#paraview.compatibility.minor = 10
#### import the simple module from the paraview
from paraview.simple import *
#### disable automatic camera reset on 'Show'
# create a new 'OpenFOAMReader'
foamcase = OpenFOAMReader(registrationName='open.foam', FileName='open.foam')
foamcase.MeshRegions = ['internalMesh']
foamcase.CellArrays = ['K_', 'U', 'alpha.liquid', 'interfaceCentre.liquid', 'interfaceNormal.liquid', 'p', 'p_rgh']
# get animation scene
animationScene1 = GetAnimationScene()
# update animation scene based on data timesteps
animationScene1.UpdateAnimationUsingDataTimeSteps()
# Properties modified on foamcase
foamcase.SkipZeroTime = 0
foamcase.CellArrays = ['U']
UpdatePipeline(time=0.1, proxy=foamcase)
foamcase.SkipZeroTime = 1
animationScene1.GoToFirst()
# create a new 'Calculator'
calculator1 = Calculator(registrationName='Calculator1', Input=foamcase)
calculator1.Function = ''
# Properties modified on calculator1
calculator1.ResultArrayName = 'KE'
calculator1.Function = '0.5*U^2'
UpdatePipeline(time=0.0, proxy=calculator1)
# create a new 'Integrate Variables'
integrateVariables1 = IntegrateVariables(registrationName='IntegrateVariables1', Input=calculator1)
UpdatePipeline(time=0.0, proxy=integrateVariables1)
SelectIDs(IDs=[-1, 0], FieldType=1, ContainingCells=0)
# set active source
SetActiveSource(integrateVariables1)
UpdatePipeline(time=0.0, proxy=plotSelectionOverTime1)
# save data
SaveData('postProcessing/KEDissipation.csv', proxy=plotSelectionOverTime1, RowDataArrays=['N', 'Time', 'avg(KE (0))', 'avg(KE (1))', 'avg(KE (2))', 'avg(KE (Magnitude))', 'avg(U (0))', 'avg(U (1))', 'avg(U (2))', 'avg(U (Magnitude))', 'avg(X)', 'avg(Y)', 'avg(Z)', 'avg(vtkOriginalPointIds)', 'max(KE (0))', 'max(KE (1))', 'max(KE (2))', 'max(KE (Magnitude))', 'max(U (0))', 'max(U (1))', 'max(U (2))', 'max(U (Magnitude))', 'max(X)', 'max(Y)', 'max(Z)', 'max(vtkOriginalPointIds)', 'med(KE (0))', 'med(KE (1))', 'med(KE (2))', 'med(KE (Magnitude))', 'med(U (0))', 'med(U (1))', 'med(U (2))', 'med(U (Magnitude))', 'med(X)', 'med(Y)', 'med(Z)', 'med(vtkOriginalPointIds)', 'min(KE (0))', 'min(KE (1))', 'min(KE (2))', 'min(KE (Magnitude))', 'min(U (0))', 'min(U (1))', 'min(U (2))', 'min(U (Magnitude))', 'min(X)', 'min(Y)', 'min(Z)', 'min(vtkOriginalPointIds)', 'q1(KE (0))', 'q1(KE (1))', 'q1(KE (2))', 'q1(KE (Magnitude))', 'q1(U (0))', 'q1(U (1))', 'q1(U (2))', 'q1(U (Magnitude))', 'q1(X)', 'q1(Y)', 'q1(Z)', 'q1(vtkOriginalPointIds)', 'q3(KE (0))', 'q3(KE (1))', 'q3(KE (2))', 'q3(KE (Magnitude))', 'q3(U (0))', 'q3(U (1))', 'q3(U (2))', 'q3(U (Magnitude))', 'q3(X)', 'q3(Y)', 'q3(Z)', 'q3(vtkOriginalPointIds)', 'std(KE (0))', 'std(KE (1))', 'std(KE (2))', 'std(KE (Magnitude))', 'std(U (0))', 'std(U (1))', 'std(U (2))', 'std(U (Magnitude))', 'std(X)', 'std(Y)', 'std(Z)', 'std(vtkOriginalPointIds)', 'vtkValidPointMask'],
FieldAssociation='Row Data')
When I run it using the pvpython interpreter, I get the following error message:
File "*[private path removed]*/calcKE.py", line 51, in <module>
File "*[private path removed]*/ParaView-5.10.1/lib/python3.9/site-packages/paraview/selection.py", line 371, in SelectIDs
_selectIDsHelper('IDSelectionSource', **locals())
File "*[private path removed]*/ParaView-5.10.1/lib/python3.9/site-packages/paraview/selection.py", line 314, in _selectIDsHelper
repr = paraview.simple.GetRepresentation(Source)
File "*[private path removed]*/ParaView-5.10.1/lib/python3.9/site-packages/paraview/simple.py", line 706, in GetRepresentation
raise ValueError ("view argument cannot be None.")
ValueError: view argument cannot be None.
Does anybody know what the problem is? Any help is highly appreciated!
