Dear Paraview Community,
I am having problems loading the following data in Paraview that contains direction dependent degrees for a VTK_LAGRANGE_QUADRILATERAL.
<VTKFile type="UnstructuredGrid" version="1.0" byte_order="LittleEndian" header_type="UInt64">
<UnstructuredGrid>
<Piece NumberOfPoints="12" NumberOfCells="1">
<PointData>
</PointData>
<CellData>
<DataArray type="Int64" Name="HigherOrderDegrees" NumberOfComponents="3" format="ascii">
2 3 12
</DataArray>
<DataArray type="Int64" Name="CellNumber" format="ascii">
1
</DataArray>
</CellData>
<Points>
<DataArray type="Float64" Name="Points" NumberOfComponents="3" format="ascii">
0 0 0 0.5 0 0
1 0 0 0 0.3333333333333334 0
0.5000000000000001 0.3333333333333334 0 1.0000000000000002 0.3333333333333334 0
0 0.6666666666666666 0 0.5 0.6666666666666666 0
1 0.6666666666666666 0 0 1 0
0.5 1 0 1 1 0
</DataArray>
</Points>
<Cells>
<DataArray type="Int64" Name="connectivity" format="ascii">
0 2 11 9 1 5
8 10 3 6 4 7
</DataArray>
<DataArray type="Int64" Name="offsets" format="ascii">
12
</DataArray>
<DataArray type="UInt8" Name="types" format="ascii">
70
</DataArray>
</Cells>
</Piece>
</UnstructuredGrid>
</VTKFile>
Reading the mesh works in Paraview 5.9.1 and fails in Paraview 5.10.0 (and later versions) with the following error message.
( 4.656s) [paraview ]vtkHigherOrderQuadrilat:598 ERR| vtkLagrangeQuadrilateral (0x1ca4dd90): The degrees are direction dependents, and should be set in the input file.
( 4.659s) [paraview ]vtkHigherOrderQuadrilat:623 ERR| vtkLagrangeQuadrilateral (0x1ca4dd90): The degrees might be direction dependents, and should be set before GetOrder is called. numPts is 12 and Order[2] 9
( 4.660s) [paraview ]vtkHigherOrderQuadrilat:623 ERR| vtkLagrangeQuadrilateral (0x1ca4dd90): The degrees might be direction dependents, and should be set before GetOrder is called. numPts is 12 and Order[2] 9
Did something change with how to specify the degrees of the cells? I am using HigherOrderDegrees CellData. I check the release notes for Paraview 5.10 but didn’t see any discussion of this.
Thanks for any help you can provide,
Lucas
