Problems with PVanimation..
Greetings, I am attempting to load .vti and.vtk files in a python script while loading a .pvsm file. I continue to receive these errors:
File "C:\Users\deyhl\anaconda3\broncho-master\PostProcess\vol_and_div\vol_and_div_ospray.py", line 8, in <module>
    from paraview.simple import *
  File "C:\Users\deyhl\anaconda3\lib\site-packages\paraview\simple.py", line 41, in <module>
    from paraview import servermanager
  File "C:\Users\deyhl\anaconda3\lib\site-packages\paraview\servermanager.py", line 3255, in <module>
    if not vtkInitializationHelper.Initialize(slist, ptype):
TypeError: arguments do not match any overloaded methods
THE CODE IS HERE:
# trace generated using paraview version 5.11.0
# To ensure correct image size when batch processing, please search
# for and uncomment the line `# renderView*.ViewSize = [*,*]`
#### import the simple module from the paraview
import sys
from paraview.simple import GetTimeKeeper
#### disable automatic camera reset on 'Show'
# get active view
# uncomment following to set a specific view size
renderView1.ViewSize = [797, 797]
# destroy renderView1
Delete(renderView1)
del renderView1
# load state
LoadState('C:\\PATH\\TO\\THE\\PVSM\\FOLDER\\div_r1s1.pvsm', DataDirectory='G:\\PATH\\TO\\VTK_AND_VTK_FILES\\',
a_divvtiFileName=[ '020_div.vti', '030_div.vti', '040_div.vti', '050_div.vti', '060_div.vti', '070_div.vti', '080_div.vti', '090_div.vti', '100_div.vti', '110_div.vti', '120_div.vti', '130_div.vti', '140_div.vti', '150_div.vti', '160_div.vti', '170_div.vti', '180_div.vti', '190_div.vti', '200_div.vti', '210_div.vti', '220_div.vti', '230_div.vti', '240_div.vti', '250_div.vti', '260_div.vti','270_div.vti', '280_div.vti','290_div.vti', '300_div.vti', '310_div.vti', '320_div.vti', '330_div.vti', '340_div.vti', '350_div.vti', '360_div.vti', '360_div.vti', '370_div.vti', '380_div.vti', '390_div.vti', '400_div.vti', '410_div.vti', '420_div.vti', '430_div.vti', '440_div.vti', '450_div.vti', '460_div.vti', '470_div.vti', '480_div.vti', '490_div.vti', '500_div.vti', '510_div.vti', '520_div.vti', '530_div.vti', '540_div.vti', '550_div.vti', '560_div.vti', '570_div.vti', '580_div.vti', '590_div.vti', '600_div.vti', '610_div.vti', '620_div.vti', '630_div.vti', '640_div.vti', '650_div.vti', '660_div.vti', '670_div.vti', '680_div.vti', '690_div.vti', '700_div.vti', '710_div.vti', '720_div.vti', '730_div.vti', '740_div.vti', '750_div.vti', '760_div.vti', '770_div.vti', '780_div.vti'],
a_divvtkFileNames=[ '020_div.vtk', '030_div.vtk', '040_div.vtk', '050_div.vtk', '060_div.vtk', '070_div.vtk', '080_div.vtk', '090_div.vtk', '100_div.vtk', '110_div.vtk', '120_div.vtk', '130_div.vtk', '140_div.vtk', '150_div.vtk', '160_div.vtk', '170_div.vtk', '180_div.vtk', '190_div.vtk', '200_div.vtk', '210_div.vtk', '220_div.vtk', '230_div.vtk', '240_div.vtk', '250_div.vtk', '260_div.vtk','270_div.vtk', '280_div.vtk','290_div.vtk', '300_div.vtk', '310_div.vtk', '320_div.vtk', '330_div.vtk', '340_div.vtk', '350_div.vtk', '360_div.vtk', '360_div.vtk', '370_div.vtk', '380_div.vtk', '390_div.vtk', '400_div.vtk', '410_div.vtk', '420_div.vtk', '430_div.vtk', '440_div.vtk', '450_div.vtk', '460_div.vtk', '470_div.vtk', '480_div.vtk', '490_div.vtk', '500_div.vtk', '510_div.vtk', '520_div.vtk', '530_div.vtk', '540_div.vtk', '550_div.vtk', '560_div.vtk', '570_div.vtk', '580_div.vtk', '590_div.vtk', '600_div.vtk', '610_div.vtk', '620_div.vtk', '630_div.vtk', '640_div.vtk', '650_div.vtk', '660_div.vtk', '670_div.vtk', '680_div.vtk', '690_div.vtk', '700_div.vtk', '710_div.vtk', '720_div.vtk', '730_div.vtk', '740_div.vtk', '750_div.vtk', '760_div.vtk', '770_div.vtk', '780_div.vtk'])
# get animation scene
animationScene1 = GetAnimationScene()
# get the time-keeper
timeKeeper1 = GetTimeKeeper()
# find view
renderView1 = FindViewOrCreate('RenderView1', viewtype='RenderView')
# set active view
SetActiveView(renderView1)
# Properties modified on animationScene1
animationScene1.AnimationTime = float(sys.argv[1])
# Properties modified on timeKeeper1
timeKeeper1.Time = float(sys.argv[1])
# current camera placement for renderView1
renderView1.CameraPosition = [639.4999999999999, 639.7709229760511, 3550.1982347636326]
renderView1.CameraFocalPoint = [639.4999999999999, 639.7709229760511, 50.64464092254639]
renderView1.CameraViewUp = [-1.0, 2.220446049250313e-16, 0.0]
renderView1.CameraParallelScale = 639.8216816140956
renderView1.CameraParallelProjection = 1
# save screenshot
SaveScreenshot('G:\Path\\to\\folder\\v.{:04d}.png'.format(int(sys.argv[1])), renderView1, ImageResolution=[797, 797])
I am on Windows 11, using VS as the interpreter. I have VTK version 9.2.2 installed and ParaView version 5.11.0. I do not understand what the problem is? Is it because the .pvsm file and the .py file are in different harddrives? Been stuck with this for a while. Thank you for any help!
