I have a very simple programmable filter that detects if an array exists or not in the input data (it uses “isinstance” in order to detect that). It works fine for PV5.4.0 and older versions but for PV5.5.0 and newer versions it is no longer working.
How can I modify it to make it work?
Please, find in the attached file 2 PVSM files: one that works fine in PV5.4.0 and the other that does not work properly in PV5.4.0.
In both cases I use this:
isinstance(inputs[0].GetPointData().GetArray("Z_VELOCITY"), vtk.numpy_interface.dataset_adapter.VTKNoneArray)
If the array “Z_VELOCITY” does not exists, its output should be “True”
Thanks in advance!
Miguel
PV_ERROR_TEST.cas (298.6 KB)
PV_ERROR_TEST.dat (491.3 KB)
STATE_error_PV5_5_0.pvsm (685.1 KB)
STATE_reference_PV5_4_0.pvsm (656.6 KB)
