I’m trying to implement at programmable filter in which I read in an existing array from an imported solution, then calculate a new array based on an “if” “else” statement. Specifically if a nodal value is greater than zero, I perform a different calculation than if it is negative.
I’m stuck where the code is trying to evaluate the data in the existing array against “>= 0”. I think it may have to do with the fact that the data type is a ‘VTKCompositeDataArray’ and I’m trying to compare it to an integer or float. The snippet below always evaluates >=0 at TRUE even though there are negative values in the solution.
Is there a way I should convert the conditional statement parameters to the same data type, or another/better way to fix this issue? I can’t quite find a solution after searching through the various examples online.
Thanks!
Brandon
Windows, Paraview v5.9.1
import numpy as np
input0 = inputs[0]
# Max principle stress midpoint value array
Sigma_m = input0.PointData["Stress_maxPrin_Mid"]
# Constants
numPoints = input0.GetNumberOfPoints()
Ct = 1.0
Sut = 1.474*10**9
# New array for output
pointArray = np.empty(numPoints,dtype=np.float64)
# Iterate through Sigma_m array, populate pointArray according to if/else statement
for i in range(numPoints):
# the next line is giving the troubles, I believe
if Sigma_m[i] >= 0:
pointArray[i] = (Ct*Sut*input0.PointData["Stress_maxPrin_Alt"])/(Ct*Sut-input0.PointData["Stress_maxPrin_Mid"])
else:
pointArray[i] = input0.PointData["Stress_maxPrin_Alt"]
output.PointData.append(pointArray,"Stress_maxPrin_r")
