I have a a model with a temperature field. I have a .csv file with the fraction solid Vs temperature data. I am trying to use a programmable filter to read in the fraction solid data, then for each cell interpolate the Fraction Solid based on the temperature data.
I’m struggling with the error:
TypeError: min() got an unexpected keyword argument ‘key’
The function getFracLiq requires a float value. I pass in float with a value not requiring interpolation then the script works (temp = 700, temp = 300). However, if it is a value requiring interpolation (temp=600), then the min function is used and the script fails with the error.
Why does the min() function produce this error, and how do I get around this issue?
Below is the python from my Programmable Filter Window,
import os
# Temperature to Fraction liquid
def getFSdata(fsFileName):
# Read in file
FSdata = [[],[]]
f1=open(fsFileName,'r')
content=f1.readlines()
for line in content:
s1=line.rstrip('\n').split(',')
FSdata[0].append(float(s1[0])) # The dataList[0] in dataList stores the time column of the model output file
FSdata[1].append(float(s1[1])) # dataList[nodeNum+1] contains the temperature evolution of Point nodeNum
f1.close()
return FSdata
# This function returns the fraction liquid at a given temperature
def getFracLiq(temp,FSdata):
#Confirm temperature within solidus liquidus range
if temp <= FSdata[0][0]:
FracSolid = 1.0
elif temp >= FSdata[0][-1]:
FracSolid = 0.0
else:
# Calculate the fraction solid by linearly interpolating data supplied
# Find closest data entry to temp
close = min(FSdata[0], key=lambda x:abs(x-temp))
if close > temp:
indexH_Cons=FSdata[0].index(close) # For temperatures higher than the constraint T, indexH_Cons is the index of the one that is closest to the constraint T
indexL_Cons=FSdata[0].index(close) - 1
else:
indexH_Cons=FSdata[0].index(close) + 1 # For temperatures lower than the constraint T, indexL_Cons is the index of the one that is closest to the constraint T
FracSolid =(FSdata[0][indexH_Cons]-temp)/(FSdata[0][indexH_Cons]-FSdata[0][indexL_Cons])*(FSdata[1][indexL_Cons]-FSdata[1][indexH_Cons])+FSdata[1][indexH_Cons]
# Calculate the liquid fraction from fraction solid
liqFrac = 1.0-FracSolid
return (liqFrac)
# Load Fraction solid data
fsFileName = r'C:\Users\Carl\Desktop\cubes_porosityParaView\paraView\FSdata.csv'
FSdata = getFSdata(fsFileName)
# Calculate the Fraction liquid of the each cell
# Obtain temperature data
#temp = inputs[0].CellData['T']
temp = 600.0
fracLiq = getFracLiq(temp,FSdata)
output.CellData.append( fracLiq , 'FracLiquid')
