programmable source failed to import text
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkDemandDrivenPipeline.cxx, line 668
vtkPVCompositeDataPipeline (000001C99BBC1D70): Input port 0 of algorithm vtkOpenGLTexture(000001C9BBB28410) has 0 connections but is not optional.
# Code for 'Script'
# We will use NumPy to read the csv file.
# Refer to NumPy documentation for genfromtxt() for details on
# customizing the CSV file parsing.
import numpy as np
# assuming data.csv is a CSV file with the 1st row being the names names for
# the columns
data = np.genfromtxt("c:/00yf/dh/time0.txt", dtype=None, names=True, delimiter=',', autostrip=True)
for name in data.dtype.names:
array = data[name]
# You can directly pass a NumPy array to the pipeline.
# Since ParaView expects all arrays to be named, you
# need to assign it a name in the 'append' call.
output.RowData.append(array, name)
