Can someone help me create an example of loading a 64x64 random numpy float32 array into a vtkImageData output for a programmable source? From there I’m confident I can apply it to my own data.
I tried the removing the third component by setting it to 0, is that what you had in mind?
#script code
import h5py
from pathlib import Path
pth = Path.home()/"Downloads/test.hdf5"
f = h5py.File(pth,"r")
data = f["data"][20]
dims = data.shape
#data = data.flatten()
output.SetExtent(0, dims[0]-1, 0, dims[1]-1,0,0)
output.PointData.append(data, "scalars")
output.PointData.SetActiveScalars("scalars")
# Code for 'RequestInformation Script'.
# we assume the dimensions are (48, 62, 42).
outInfo.Set(executive.WHOLE_EXTENT(), 0, 63, 0, 63,0,0)
outInfo.Set(vtk.vtkDataObject.SPACING(), 1, 1,0)
For some reason it thinks all my data is the same value, when the values that are in the test.hdf5 are actually a (500,64,64) array of floats from a PDE solver. Can the images only be uint8? is that part of the problem?
Ok, nvm. There seemed to be something going on where when I didn’t flatten the data it wouldn’t associate the value with an invididual cell in the image. This seems to work for my purposes.
import h5py
import numpy as np
dims = data.shape
rand =( np.random.random(data.shape)*255).flatten()
print(data.shape)
I guess I thought perhaps an image was simplistic enough to not have to fill out a request information script.
If I wanted to get a comprehensive handle on all the programmable source export types and how they relate to vtk python coding what resource would you point me to?
