Programmable source - Threshold Unstructured Grid update when changing time step
Hi All,
I am trying to write a programmable source which will update the range of a threshold when changing timesteps. Essentially what I want to do is plot the FWHM as an animation. I was looking back at a script I wrote for Paraview 4, but I thought I would give it a go for the latest version, and try using the paraview.simple module. However, I am getting stuck at the last line, where I need to shallow copy the data from the threshold to the sources output, as I get the error object has no attribute ‘GetOutput’ which I can see is the case from the paraview.simple documentation. However I am unsure which method I need to use instead!
Here is my script - there is a source called recon_* which I references specifically, which might not be the most portable way of doing it.
import paraview.simple
s=paraview.simple.FindSource('recon_*')
t=paraview.simple.Threshold(Input=s)
output=self.GetOutputDataObject(0)
cd=s.CellData[0]
DataRange=cd.GetRange(0)
minthres= -10
maxval = -500
#maxval = DataRange[0]
fwhm=DataRange[0] * 0.5
print "fhwm : " + str(fwhm)
if fwhm < minthres:
current_min_thres = minthres
else:
current_min_thres=fwhm
t.ThresholdRange=[maxval, current_min_thres]
print "current thres : " + str(current_min_thres)
output.ShallowCopy(t.GetOutput())
Thanks for any help you can offer :slight_smile:
The script you are trying to build does not go in a Programmable Source (or Programmable Filter). ParaView UI scripts (those that use the paraview.simple bindings) are run from the Python Shell (View -> Python Shell) or bound to a macro.
These scripts do not have direct access to the data (unless you explicitly download it to the client, which is not a good idea). That is why GetOutput is not available. However, when a ParaView UI script creates a filter (like Threshold), it will be available in the Pipeline Browser, so its data will be available just like any other filter.
Oh I see! Rookie error. Thanks for that. I got it working as a programmable filter with the following code
from vtk import vtkThreshold
inp = self.GetInputDataObject(0, 0)
outp = self.GetOutputDataObject(0)
#Get min/max values
aa = inputs[0].CellData
ai = aa[0]
Range = ai.GetRange(0)
#Define threshold filter
thresh = vtkThreshold()
thresh.SetInputData(inp)
minthres= -1
maxval = -500
#maxval = Range[0]
fwhm=Range[0] * 0.5
if abs(fwhm) < abs(minthres):
else:
#Set threshold to half min
thresh.ThresholdBetween(maxval,current_min_thres)
thresh.Update()
outp.ShallowCopy(thresh.GetOutput())
It seems like paraview doesnt like the min function?
