I have a programmable source that creates a Delaunay2D mesh from Numpy arrays. Now I want to calculate the vorticity from the vector field but “algs.vorticity(Vector_Speed)” do not work because “Vector_Speed” is a numpy object. The same happens with the “algs.gradient(Vx)” (because “Vx” is a numpy array)
Since I really want to use the “algs.vorticity” function, I tried to convert the numpy vector (i.e., “Vector_Speed”) into a vtk object and then to wrap this element but I cannot make it work. Please, can you provide me some guidelines to solve this issue?
Thanks in advance!
PS: the programmable source must be a vtkPolyData (vtkImage is not an option for my application)
Miguel
# MODULES LOAD:
import numpy as np
import vtk
from vtk.numpy_interface import algorithms as algs
from vtk.numpy_interface import dataset_adapter as dsa
import paraview.vtk.util.numpy_support as vnp
# NUMPY INPUT DATA:
X=np.array([0,1,2,0,1,2]) # X-coordinate
Y=np.array([0,0,0,1,1,1])
Z=np.array([0,0,0,0,0,0])
Vx=np.array([0,1,2,0,1,2]) #X-velocity
Vy=np.array([0,0,0,0,0,0])
Vz=np.array([0,0,0,0,0,0])
# DELAUNAY PLANE CREATION:
points = vtk.vtkPoints()
for i in range(X.size):
points.InsertNextPoint(X[i],Y[i],Z[i])
aPolyData = vtk.vtkPolyData()
aPolyData.SetPoints(points)
aCellArray = vtk.vtkCellArray()
boundary = vtk.vtkPolyData()
boundary.SetPoints(aPolyData.GetPoints())
boundary.SetPolys(aCellArray)
delaunay = vtk.vtkDelaunay2D()
if vtk.VTK_MAJOR_VERSION <= 5:
delaunay.SetInput(aPolyData.GetOutput())
delaunay.SetSource(boundary)
else:
delaunay.SetInputData(aPolyData)
delaunay.SetSourceData(boundary)
delaunay.Update()
self.GetOutput().ShallowCopy(delaunay.GetOutput())
# GRADIENT AND VORTICITY:
Vector_Speed = algs.make_vector(Vx,Vy,Vz)
#VORTICITY = algs.vorticity(Vector_Speed) #This fuction is not working here because Vector_Speed is a numpy element
#CONVERTING THE NUMPY VECTOR INTO A VTK ARRAY
vtkdata = vnp.numpy_to_vtk(Vector_Speed.ravel(), deep=True, array_type=vtk.VTK_FLOAT)
vtkdata.SetNumberOfComponents(3)
vtkdata.SetName("Vector_Speed")
#HERE I TRY TO WRAP THE VTK ELEMENT (but fails!)
WrapData = dsa.WrapDataObject(vtkdata.GetOutput())
Vector_Speed = WrapData.PointData["Vector_Speed"]
# THIS IS WHAT I WANT TO CALCULATE
Vx_GRADIENT = algs.gradient(Vx)
